[Qgis-user] MacOS installation: GSL?
William Kyngesburye woklist at kyngchaos.com
Thu Jan 29 07:22:39 PST 2015
SQLite3 is NOT needed separately.  Are you sure you downloaded the most recent GDAL Complete and QGIS? There was a change in December in SQLite3 (part of GDAL Complete) that required a rebuild of QGIS.  So if you have an old copy of one and new other, they won't work together.  QGIS and GDAL versions did not change, just the builds, so it may be confusing.
GDAL Complete is a collection of frameworks, what's needed for GDAL to function.  The frameworks are listed in the readme: GDAL, PROJ, GEOS, SQLite3, UnixImageIO, plust the NumPy Python module.  Other than the major GDAL version, I only version the whole package by date in the readme, since any of the bits can change.  Get Info on the frameworks to see which of each version is installed.
On Jan 29, 2015, at 8:59 AM, Lars Huttar <huttarl at gmail.com> wrote:
> Thanks, Junior and William.
> I ended up installing GSL separately just in case. (And I made sure I already had MatPlotLib.) But it's good to know that, at least in the mailing list archives, we've straightened out the fact that as of 2.6, it's not necessary to install GSL separately.
> Incidentally, when I ran the QGIS installer, it told me that SQLite 3 was a missing requirement, and wouldn't continue the installation.
> So I installed SQLite 3, after which the QGIS installer worked fine.
> So I guess SQLite 3 should be added to the requirements on both of the web pages mentioned below? So the list should be:
> - GDAL Complete
> - SQLite 3
> - MatPlotLib
> Another nice bit of info to have somewhere would be, how do I tell what I already have installed? E.g. last night before I installed GDAL Complete (having installed QGIS 2.4 and GDAL in the past), I had /Library/Frameworks/GDAL.framework, and I wasn't sure if that was GDAL Complete or just GDAL. So I installed GDAL Complete; but it apparently installed in the same folder. And the /Library/Frameworks/GDAL.framework/Versions directory still has the same contents as before: 1.11 and Current (which is a symlink to 1.11). So how do I know whether I have GDAL Complete? And similarly for the other requirements.
> Thanks for all your contributions to make QGIS available and usable for the masses!
> Lars
> On 1/29/15 9:38 AM, William Kyngesburye wrote:
>> GSL is NOT needed, it's packaed inside the app.  I'm sure I asked someone to remove that from the QGIS site but nothing was done about it.
>> On Jan 28, 2015, at 9:18 PM, Lars Huttar <huttarl at gmail.com> wrote:
>>> Hi,
>>> I looked at the installation notes for Mac OS X at https://www.qgis.org/en/site/forusers/download.html, where it says
>>> "This version requires separate installation of dependency frameworks (GDAL Complete and GSL) , also found at the download link below."
>>> The link below is http://www.kyngchaos.com/software/qgis
>>> But on that page, I find no mention of GSL, only GDAL. (I figured out that GSL refers to the GNU Scientific Library, FWIW.)
>>> One other requirement is listed on the kyngchaos.com web site (and not on the QGIS.org download page): the MatPlotLib python module.
>>> So I'm confused ... do I really need to install GSL separately, and if so, where can I find an installer for Mac OS X?
>>> And is the kyngchaos.com web page in error, or is the GQIS.org download page out of date?
>>> The previous version of QGIS that I have installed, v2.4, seems to have GSL inside it:
>>> /Applications/QGIS.app/Contents/Frameworks/GSL.framework
>>> Thanks,
>>> Lars
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
