[Qgis-user] qgis and grass7
Gustavo Martínez
gmpuljak at yahoo.com.ar
Wed Jul 1 07:06:44 PDT 2015
Hello,
I've been working with Qgis 2.8 in Linux Mint 17-64bit without problems.
The only error I've found in my use case was when I tried to connect
with Grass7.
When looking in the web, I noticed that the grass plugin will be updated
for grass7 in Qgis 2.10. I've installed the 2.11.0-Master from:
deb http://qgis.org/ubuntugis-nightly trusty main
With this version, I have the same problem. When I open the qgis log it
shows:
2015-07-01T10:32:58 1 No se pudo cargar
/usr/lib/qgis/plugins/libgrassplugin6.so (motivo: Cannot load library
/usr/lib/qgis/plugins/libgrassplugin6.so: (libgrass_vect.so: no se puede
abrir el archivo del objeto compartido: No existe el archivo o el
directorio))
libgrass_vect.so does not exist. I tried creating a link to
libgrass_vector.7.0.so but qgis does not starts and shows a message of
segment violation.
Is there anything I can do?
Many thanks,
Gustavo
Gustavo Martínez
Skype: gmpuljak
Linkedin: http://ar.linkedin.com/in/gustavomartínezpuljak
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150701/03adaac6/attachment.html>
