[Qgis-user] Profile tool - Error in the sampling points
Martin Stubbs martin at mstubbs.co.uk
Thu Jul 2 13:35:02 PDT 2015
I have been using the profile tool plugin very successfully for some
time but I now have an application where I need to know the coordinates
of the sample points. I have added a few lines to the software to allow
me to output the coordinates as well as the height points. This shows a
problem with the calculation of the sample points.
I have a DXF file which I import in QGIS to use as the sample line. When
I compare the points that were sampled to the original sample line I
find a consistent error of approx 6m in the SE direction. I have tried
converting the DXF line to a shapefile and the error is the same. I
assume that the error is some type of projection error but all layers,
the project and the DXF file are in the same EPSG:27700 (OSGB) projection.
I have created a much simpler DXF file and this doesn't show the error.
Does anyone have any ideas or suggestions?
Martin
