[Qgis-user] Automated / saved work flows?
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Jul 6 18:35:35 PDT 2015
Yup,
Processing plugin will permit you to make models and save them. It give you access to QGIS, Grass, gdal,lastools.....
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jul 6, 2015 7:47 PM, "Matt Boyd [via OSGeo.org]" <ml-node+s1560n5214525h36 at n6.nabble.com> wrote:
Hi QGISers, I'm wondering if there's a plug in or some way to save a series of steps in QGIS. One way I can think of doing it is to simply save the text / command line part of the gdal commands into a text / batch file which I could then use to string a series of command together, using the output from the first as the input to the second and so on. I've used programs that do this sort of thing more or less using a GUI. Is there anything similar for QGIS? Regards MattĀ
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Automated-saved-work-flows-tp5214525.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Automated-saved-work-flows-tp5214525p5214529.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150706/86797123/attachment.html>
