[Qgis-user] Problem using gdal_grid interpolation
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed Jul 8 11:51:48 PDT 2015
Are you using gdal-grid via the raster menu or the via the processing plugin.  Post the command you used here.
It is possible you have an extra space or character in the command.  Are you modifying the command or letting QGIS writing it for you?
You can also trouble shot by copying the command ( if you are using it via the raster menu) and copying it directly at the command prompt.  If you add "--debug on" you will get more info.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Jul 8, 2015 14:40, "Ferruccio Sarra-2 [via OSGeo.org]	" <ml-node+s1560n5214926h67 at n6.nabble.com> wrote:
Hi all, I am new to Qgis. Can I count on someone help!?  While using a Grid (Interpolation) algorithm... "The process failed to start. Either the invoked program is missing, or you may have insufficient permissions to invoke the program". A similar problem have been arisen for Mac OSX (qgis-user mailing list archive). Any clue for a a Qgis 2.8.1 installation on Fedora 21? (I have just followed the step by step installation guide on qgis site). Thanx,  Fer
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Problem-using-gdal-grid-interpolation-tp5214926.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-using-gdal-grid-interpolation-tp5214926p5214929.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150708/b36472b2/attachment.html>
