[Qgis-user] QGIS 2.8.2 GPS Tools and Garmin USB Connection
Antonio Di Marco a.dimarco at arpat.toscana.it
Thu Jul 9 07:34:55 PDT 2015
In QGIS 2.8.2 I couldn't download my Garmin GPS waypoints through Vector
-- GPS Tools menu under an USB connection.
The device has this Command line under "Waypoint download":
%babel -w -i garmin -o gpx "%in" "%out"
I tried also this line: gpsbabel -w -i garmin -o gpx "%in" "%out"
In both cases I get this message:
Layer is not valid: The layer xxxx.gpx?type=waypoint is not a valid
layer and can not be added to the map
I need an usb connection not a serial one via COM1
To verify that was not a driver trouble or something else  I tried to
gat the waypoints via GPSBABEL and everything is ok
Any answer will be very much appreciated
Antonio Di Marco
ARPAT (Agenzia Regionale per la Protezione Ambientale della Toscana)
Direzione tecnica - Settore SIRA (Sistema Informativo Regionale Ambientale)
Via N. Porpora, 22
50144 Firenze
Tel.: +39-055-3206416  Fax: +39-055-3206324
email: antonio.dimarco at arpat.toscana.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150709/d071f429/attachment.html>
