[Qgis-user] Deleted decimals in field calculator
DelazJ delazj at gmail.com
Fri Jul 10 10:50:28 PDT 2015
Francesc, I may be wrong since I couldn't find the reference in QGIS docs
nor elsewhere but I'm not sure you can have a field width at 3 and decimals
at 3. The width is supposed to be the total of all digits, meaning the
digits before the comma and those after the comma. In your case you should
have width 6 and precision 3.
Try with this and let us know.
DelazJ
2015-07-10 19:39 GMT+02:00 José Antonio Barreña Cayuela <jabarcay at gmail.com>
>  Perhaps the problem is the operating system or program language (spanish,
> english....).
> El 10/07/15 a las 18:52, Francesc Cañas escribió:
> No, it's not integer or float with no decimals. They don't dissapear when
> I save, they turn to 0 but with the same accuracy intended. If I create a
> field with 3 width and 3 decimals, while operating displays 123.321 but as
> soon as I save it turns to 123.000, the same for 4 decimals and so on.
> 123.0000. It's driving me crazy.
> 2015-07-08 10:53 GMT-05:00 Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
>> Hi,
>> Maybe you creating an integer field and not a float field (or a float
>> field with no decimals) by mistake?
>> Nicolas Cadieux M.Sc.
>> Les Entreprises Archéotec inc.
>> 8548, rue Saint-Denis Montréal H2P 2H2
>> Téléphone: 514.381.5112  Fax: 514.381.4995
>> www.archeotec.ca
>>  On Jul 8, 2015 11:19 AM, "Francesc Cañas [via OSGeo.org] " <[hidden
>> email] <http:///user/SendEmail.jtp?type=node&node=5214893&i=0>> wrote:
>>    Hi,
>> Several times when I've created a float field with the calculator, while
>> it isn't saved, it displays the decimals, but as soon as I save the
>> changes, all of them change to 0. Why this happen? It seems random to me,
>> in some shp work well but in others doesn't.
>>  Thanks a lot.
>>  *Francesc Cañas <http://francescsig.info/>*
>> Ambientoleg SIG <http://francescSIG.info>
>>  <http://aixonoesunblog.blogspot.com>
>>  _______________________________________________
>> Qgis-user mailing list
>> <a
>> href="/user/SendEmail.jtp?type=node&node=5214880&i=0">[hidden
>> email]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> http://kikocanas.tk
>>  If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/Deleted-decimals-in-field-calculator-tp5214880.html
>>  To start a new topic under Quantum GIS - User, email
>> <ml-node%2Bs1560n4125267h38 at n6.nabble.com>
>> ml-node+s1560n4125267h38 at n6.nabble.com
>> To unsubscribe from Quantum GIS - User, <a href="
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node&%2361;4125267&code&%2361;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&%2361;&%2361>
>> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
>> here.
>> <a href="
>> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
>> style="font:9px serif">NAML
>> View this message in context: Re: Deleted decimals in field calculator
>> <http://osgeo-org.1560.x6.nabble.com/Deleted-decimals-in-field-calculator-tp5214880p5214893.html>
>> Sent from the Quantum GIS - User mailing list archive
>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
>> Nabble.com.
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> *Biólogo (botánico). Servicios Medioambientales*
> *+34 677 811 883* · <jabarcay at gmail.com>jabarcay at gmail.com
>    [image: skype]   [image: linkedIn]
> <http://es.linkedin.com/pub/jos%C3%A9-antonio-barre%C3%B1a-cayuela/26/936/15a/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150710/e07feb56/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150710/e07feb56/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150710/e07feb56/attachment-0001.png>
