[Qgis-user] HELP Please: SAGA, GRASS 6 & 7, R, do not work in vers. 2.4 -. 2.8
Velizar Strumberger
velizar.strumberger at gmail.com
Tue Jul 14 03:26:39 PDT 2015
Hello to all
I am a great admirer of QGIS but I have a serious problem and I hope that
there is someone that can help me. I started working with QGIS 2.2
(Valmiera) and it worked OK. I then (tried to) switched to QGIS 2.4 but
then GRASS, SAGA and R stopped working. I have a laptop Windows 7 64 bit
and a desktop Windows XP 32 bit. The phenomenons are the same.
Installing it as a standalone or with OSGeo4W gave the same results.
These are the problems:
GDAL: OK it woks
For *GRASS 6 and 7*: Missing dependency. This algorithm cannot be run :-(
This is for *SAGA and TauDEM* : Ooooops. The following output layers could
not be open
Channel Network C: *and a log path *...........................
The above file(s) cannot be opened, which probably indicates that they were
not correctly produced by the executed algorithm.
*For R*: Missing dependency. This algorithm cannot be run :-(
* Orfeo Toolbox*:
OTB folder not configured. Please configure before running OTB algorithms.
(This also didn't work in QGIS 2.2 but I didn't bother with his).
In the Processing->Options->Providers the paths for
GRASS 6.4.3 was C:/OSGeo4W64/apps/grass/grass-6.4.3/etc/grass-run.bat
and for MSYS
C:/OSGeo4W64/apps/msys/msys.bat
This is wrong because I installed a standalone version and there is no
OSGeo4W64 folder.
I corrected the paths for both and pressed OK. I opened the Providers once
again and saw that the two path were converted to the "original" ones that
I "changed"; there is no way I can change the paths set up during the
installation
There is also a path for GRASS 7, but this was not installed.
I have the impression that parameters for the Providers is from the
previous installation through OSGeo4W - the previous installation.
I truly believe that I did not uninstall or delete a file (I also think
that the first time I did not uninstall but just deleted QGIS) that
determines such behavior because I also noticed the following:
When I install QGIS (any version) and install some plugins (which I would
never use - as a test) and open the toolbox with several providers and when
I uninstall this version and install it once again I find that the same
plugins are installed and the toolbox is opened exactly the same as I left
it in the previous installation.
I am not a computer wiz but just a humble geologist who wants to use
software for my work.
Help - or explanation how to correct this would be most welcome.
Regards
Dr. Strumberger
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150714/4eddac90/attachment.html>
