[Qgis-user] Point to absolute X,Y
Alexandre Neto senhor.neto at gmail.com
Tue Jul 21 01:43:33 PDT 2015
Hello Malin,
For that pourpose you can use the following plugin:
https://plugins.qgis.org/plugins/numericalVertexEdit/
Hope it helps.
Alexandre
On Tue, Jul 21, 2015 at 9:06 AM, Bernd Vogelgesang <bernd.vogelgesang at gmx.de
> wrote:
>  Hi,
> I do not know of a way to move a point to a certain coordinate.
> For creation, there are several options:
> Activate the Advanced Digitizing Panel (Right-click into the the menu bar).
> When activating the Add Feature Button for your point layer, the panel
> becomes active and you see a x and y-field.
> Tick the locks behind them and enter the coordinates, then click into the
> canvas and the point should be at the desired location.
> You need at least QGIS 2.8 for that, for older versions this is a separate
> plug-in.
> See https://www.youtube.com/watch?v=QsjmLa16obs for some explanations.
> For more points, use import as csv-file with Add Delimited Text Layer.
> Am 21.07.2015, 09:40 Uhr, schrieb Malin Undin <malin.undin at gmail.com>:
> xx
> Hello
> How do I move a waypoint to/create a way point at a known coordinate (X,Y)?
> (QGIS 2.8)
> Thanks
> Malin
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150721/5b2523af/attachment.html>
