[Qgis-user] QGIS 2.10 with / without GRASS 6.4.3
Radim Blazek
radim.blazek at gmail.com
Fri Jul 24 03:53:38 PDT 2015
On Fri, Jul 24, 2015 at 9:14 AM, Chris Buckmaster
<chris.buckmaster at runnymede.gov.uk> wrote:
> I am on Windows Vista 64 bit - I downloaded the windows 64 bit installer file from qgis.org
The only difference is that "QGIS Desktop 2.10.1 with GRASS 6.4.3"
loads GRASS 6 provider + plugin while "QGIS Desktop 2.10.1" does not.
No big gain running the version without GRASS, probably few tenths of
second on start.
I am not win package maintainer so I am not sure why there is the
version without GRASS.
BTW: GRASS 7 is not yet ported to win 64 bit.
Radim
> Chris
> -----Original Message-----
> From: Radim Blazek [mailto:radim.blazek at gmail.com]
> Sent: 23 July 2015 20:06
> To: Chris Buckmaster
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] QGIS 2.10 with / without GRASS 6.4.3
> On Thu, Jul 23, 2015 at 1:33 PM, Chris Buckmaster <chris.buckmaster at runnymede.gov.uk> wrote:
>> Hi there
>> I have installed the new version of QGIS but notice it now comes with
>> two different desktop applications; one with and one without GRASS 6.4.3.
>> Is there any reason for this and should I be using each of them
>> depending on what I am wanting to carry out? Just a bit confused with which one to use.
> Which platform, which package? If it is from OSGeo4W, there are two batch files (the QGIS application is the same) which start QGIS either with GRASS 6 or GRASS 7 (you have to manually select GRASS 7 package in OSGeo4W setup if you want to use QGIS with GRASS 7 provider).
> Radim
>> Thanks
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
