[Qgis-user] problem scaling labels in Qgis 2.10
Alexandre Neto
senhor.neto at gmail.com
Fri Jul 24 06:15:48 PDT 2015
On the other hand, while setting your labels sizes and positions you should
set the map canvas scale to the one that will be used in the Print
Composer. This, will ensure that you have an exact notion of the relative
size and position of all features and labels the way they will came out of
the composer's output.
Hope it helps.
Alexandre Neto
Em qui, 23 de jul de 2015 às 17:46, Donovan Cameron <sault.don at gmail.com>
escreveu:
> You can set the label size to map units (ie, metres) instead of font pt.
> That should help with scaling.
> Donovan
> On 23/07/15 09:31 AM, Richard McDonnell wrote:
> Try viewing the data in the canvas in the same scale as you wish to view
> it in the composer, you may also try to use data defined label placing, for
> the troublesome ones.
> Regards,
> Richard.
> On 23/07/2015 11:58, Rachel Brouwer wrote:
> I'm currently using Ubuntu - QGis 2.10.0 Pisa.
> When using the print Composer I have discovered my labels (size 8) are all
> of sudden a whole lot bigger and for this reason overlapping. How can I
> make sure that the size stays the same after going into the print composer?
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
> OPW - Looking to the future - Caring for the past
> <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> Kind regards,
> Donovan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150724/9fb3eb02/attachment.html>
