[Qgis-user] Georeference'd maps off by 200m
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Jul 27 19:33:31 PDT 2015
When you use the georeferencer, you need to indicate the CRS of the the source file and of the the output file. Perhaps that step was not done properly. I have had this type of problems in the past and it had to do with me changing the CRS during the process. Perhaps the output file CRS was changed and that change was not recorded. Generally speaking, the module works and will reproject to anything. Make sure the project CRS is the same as what the output should be for extra precaution.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jul 27, 2015 18:45, "Nick Papadonis [via OSGeo.org] " <ml-node+s1560n5217272h93 at n6.nabble.com> wrote:
I was able to get everything to line up correctly by changing the layer property CRS from WGS84 UTM to EPSG:26718 NAD27 UTM. I was expecting the new raster to have WGS84 coordinates and the projected image with it. It seems the coordinates are still referencing the NAD27 projection after the they should not. Therefore I’m wondering if the Georeferencer pluging reprojects or not.
Thanks
> On Jul 27, 2015, at 6:19 PM, Nick Papadonis < [hidden email] > wrote:
> Hi Folks,
> I’m trying to scan in a topographic map into a georeferenced raster so I can trace vector over it. I have been playing with the plugin for a few hours and am having odd results. I’m hoping an expert here can point me in the right direction. The issue is when I finally open the resulting TIFF file as a raster layer it appears the raster is 200m too far to the south. It also appears this is a uniform error across the map. The east and west line up fairly well. I was suspecting something with the projection choices or coordinate systems. I figured the coordinate system translation code would have already had plenty of use in the community by now. When creating the TIFF I used 10 coordinate points and Projective/Cubic. I also tried 2-degree poly with similar results. For the target SRS I used EPSG:32618 WGS84 UTM. The raster source is EPSG:2032 NAD27 UTM Zone 18N. The two vector data sources I checked agree and are EPSG:4326 WGS 84. I tried to create the TIFF in this format, however it ended up in the wrong coordinates when loaded as a layer.
> Any tips or tricks appreciated.
> Thanks,
> Nick
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Georeference-d-maps-off-by-200m-tp5217271p5217272.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Georeference-d-maps-off-by-200m-tp5217271p5217285.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150727/7d1861de/attachment.html>
