[Qgis-user] Convert data DXF (autocad R12) to QGIS
Rémi Cura
remi.cura at gmail.com
Tue Jul 28 03:30:34 PDT 2015
Hey,
you can use GDAL to convert your autocad format to another (like shapefile).
Let's be honnest though, it is far from a 100% compatibility.
If you have a licence, you can also use FME
http://www.gdal.org/drv_dwg.html
Cheers,
Rémi-C
2015-07-13 15:04 GMT+02:00 Peteris Bruns <pb at sungis.lv>:
> Hi Marco and Andreas,
> if there is potential plan to use Teigha DWG Library from OpenDesign
> Alliance, then probably is worth to include import support for MicroStation
> DGN v8.
> We are interested in this development. For sure we can provide test data
> (DWG/DGN), and I believe we are ready something to fund also.
> Best regards,
> On 2015.07.02. 10:58, Andreas Neumann wrote:
> Hi Marco,
> In the soon to be released 2.10 version and also in the upcoming 2.8.3
> release (probably released in the second half of July) you can find a much
> improved DXF export.
> See http://www.qgis.ch/en/projects/dxf-export for more details of the DXF
> export.
> We will work on DXF/DWG import in the next 1-2 releases. We have started
> to work on a requirements document here:
> https://docs.google.com/document/d/1NJv1lwd5TnWdV-fTuW7g5ts1O8r3vb46xYeAIQ_BwGw/edit?usp=sharing
> Your input to the requirements document will be welcome. Also, we would
> appreciate if you could help finance this effort - if possible. We will
> soon ask a dev for a quote how much this will cost and then approach the
> QGIS users to help fund this effort.
> Note that it is definitely not possible to round-trip GIS to CAD and back.
> CAD data is not a GIS format and vice versa. But we will do our best to
> help bridge the two worlds.
> Best regards,
> Andreas
> On 02.07.2015 09:07, Marco Boogaard wrote:
> Hello,
> I want to convert DXF (R12) data to QGIS and vise versa.
> Is this possible with QGIS? And do you need a plugin or script?
> Thanks.
> Regards
> Marco Boogaard
> www.gis-specialist.nl
> Schrijf u in voor de nieuwsbrief <http://eepurl.com/uybj9> en volg ons
> op Twitter <http://www.twitter.com/gis_specialist>.
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> Pēteris Brūns
> SunGIS
> +371 26336691pb at sungis.lv
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150728/739813a7/attachment.html>
