[Qgis-user] how to avoid the automatic conversion of a session string in a csv file to a number
CONTI Tonino t.conti at comune.jesi.an.it
Wed Jul 29 01:18:43 PDT 2015
Dear all,
Can anyone tell me how to prevent qgis automatically convert a csv file from text field to numeric format (double).
I have a csv file where a field contains texts starting with zero (example: "0420050000000009", with the quotes).
When I add to my project file as "layer delimited text," I see the data properly in the preview but when the layer is added in this field is not imported the leading zero recognizing the format as numeric.
I need that the string "0420050000000009" remains unchanged as it represents a unique identifier.
can you help me?
Thank You
Tonino
Dott.Tonino Conti
Comune di Jesi
Sistema Informativo Territoriale
 Tel 0731538312 - fax 0731538513
t.conti at comune.jesi.an.it<mailto:t.conti at comune.jesi.an.it>
www.comune.jesi.an.it/sit<http://www.comune.jesi.an.it/sit>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150729/e5493a42/attachment.html>
