[Qgis-user] Transferring QGIS work when you used a PostGIS database
Junior Delaz
delazj at gmail.com
Fri Mar 6 02:46:32 PST 2015
Tom, I haven't tried it but i saw these days a new QGIS plugin that aims to
do similar thing : convert any GIS format data in the project to shp (in a
single directory). It's name is QPackage [0]
There is also another plugin QConsolidate [1] that groups all the data into
an unique directory but I don't know how it deals with database files.
[0] https://plugins.qgis.org/plugins/QPackage/
[1] https://plugins.qgis.org/plugins/qconsolidate/
Hope it helps...
2015-03-05 6:20 GMT+01:00 Leahy, Thomas A. <tleahy at bechtel.com>:
> Hello,
> If I just use shape and raster files it is fairly easy for me to give
> someone all my QGIS work on a USB stick as it uses relative directory
> references as long as everything is below the Project Directory they can
> use it as I did. However if I decide to use PostGIS is there an easy way to
> similarly transfer the work that was done to another person?
> Thanks for your assistance,
> Tom Leahy
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150306/eab441f1/attachment.html>
