[Qgis-user] GRASS dependency problem on OS X
Howard Frederick simbamangu at gmail.com
Tue Mar 10 06:56:01 PDT 2015
It allows GRASS to be activated in the Processing options, but gives the
dependency error if I actually try to run any of the tools.
The OS X console logs this when this failure happens:
10/03/15 16:42:05.779 QGIS[3835]: modalSession has been exited prematurely
- check for a reentrant call to endModalSession:
On 10 March 2015 at 16:25, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> Does it allow you to turn on GRASS in Processing?  If so, you can see what
> the actual error is in the algorithm output when you try to run one if you
> turn on the Processing option to leave windows open when done.
> On Mar 9, 2015, at 11:47 PM, Howard Frederick <simbamangu at gmail.com>
> wrote:
> > Frustrating and inconsistent problem with GRASS dependency in QGIS 2.8
> (and 2.6 before upgrading).
> > I get the usual "unmet dependency" error when trying to run any GRASS
> tool - but the Options link correctly to the location of the grass folder
> inside QGIS.app.
> > I have done a clean install, removing the preferences
> (org.qgis.QGIS2.plist), the .qgis2 folder and anything else I could find,
> but the problem persists.
> > The puzzle: on the same machine, if I create a new user and log in,
> GRASS tools run just fine in QGIS, with no modifications of the Processing
> configuration! Seems there is some configuration file that is messing with
> things - or possibly a path setting?
> > Any suggestions as to what I could look for?
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the
> past isn't a fiction designed to account for the discrepancy between my
> immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150310/d072404f/attachment.html>
