[Qgis-user] Attribute copy from point to polygon (Joris Hintjens)
abhijit.ekbote at gmail.com
Sat Mar 14 18:31:37 PDT 2015
Hi
One of the method is to use Spatial Join to transfer attributes of point to polygon. This works if the point is spatially located withing the polygon to whom you want to attach the attributes to.
The other method is to join attributes of point to polygon based on a attribute which is common to both and is present in both attribute tables.
Hope this helps.
Abhijit
Original Message
Sent: Sunday 15 March 2015 06:56
To: qgis-user at lists.osgeo.org; qgis-user at lists.osgeo.org
Subject: Re: Qgis-user Digest, Vol 109, Issue 27
Hi
Hope this helps.
Abhijit
Original Message
Sent: Sunday 15 March 2015 00:31
Reply To: qgis-user at lists.osgeo.org
Subject: Qgis-user Digest, Vol 109, Issue 27
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
qgis-user-request at lists.osgeo.org
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
1. Re: Attribute copy from point to polygon (Joris Hintjens)
2. Re: Attribute copy from point to polygon (Lene Fischer)
Message: 1
Date: Sat, 14 Mar 2015 13:44:19 +0100
To: Raymond Nijssen <r.nijssen at terglobo.nl>
Cc: QGIS User <Qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Attribute copy from point to polygon
Message-ID: <3A4EF06E-C207-4410-895C-076DA1FB7E51 at gmail.com>
Content-Type: text/plain; charset=windows-1252
Ahah!
our beloved Ujaval again!
bedankt, Raymond. Ik had die optie al geprobeerd natuurlijk, maar kwam tot een vreemd resultaat. (een point layer met alleen features daar waar de polygonLayer ene?null? value had in een bepaalde kolom.
Toen ben ik op zoek gegaan naar een alternatief. Nu nog eens geprobeerd, en het werkt wel.Waarschinijk bij de eerste poging(en) verkeerde parameters ingevuld, dat kan ik nu niet meer nagaan.
toch bedankt, het lukt me nu wel.
Joris
> Op 12-mrt.-2015, om 12:33 heeft Raymond Nijssen <r.nijssen at terglobo.nl> het volgende geschreven:
> http://www.qgistutorials.com/nl/docs/performing_spatial_joins.html
> ps use google too ;)
> On 12-03-15 12:22, Joris Hintjens wrote:
>> Hi,
>> I have a pointlayer and polygon layer in .SHP.
>> I need to copy an attribute from the points within each polygon to the
>> polygon layer.
>> Any suggestions on how to do this?
>> thanks
>> Joris
> Terglobo
> Amp?restraat 110
> 5223 CT 's-Hertogenbosch
> 06-25314983
Message: 2
Date: Sat, 14 Mar 2015 14:20:42 +0000
To: Joris Hintjens <jorishin at gmail.com>, Raymond Nijssen
Message-ID:
<38497AD9CA059C42AA3451EFEFF0378ED7224C61 at P2KITMBX04WC02.unicph.domain>
Content-Type: text/plain; charset="iso-8859-1"
Try the point sampling tool
Lene Fischer
Associate Professor
Department of Geosciences and Natural Resource Management
University of Copenhagen
MOB +45 40115084
lfi at ign.ku.dk
-----Oprindelig meddelelse-----
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] P? vegne af Joris Hintjens
Sendt: 14. marts 2015 13:44
Til: Raymond Nijssen
Cc: QGIS User
Emne: Re: [Qgis-user] Attribute copy from point to polygon
Ahah!
bedankt, Raymond. Ik had die optie al geprobeerd natuurlijk, maar kwam tot een vreemd resultaat. (een point layer met alleen features daar waar de polygonLayer ene"null" value had in een bepaalde kolom.
Joris
>> Hi,
>> the polygon layer.
>> thanks
>> Joris
> Terglobo
> Amp?restraat 110
> 06-25314983
End of Qgis-user Digest, Vol 109, Issue 27
