[Qgis-user] QGIS on WinXP
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Mar 16 16:27:59 PDT 2015
I installed 2.6.1 on XP two weeks ago using the OSGEO4W install without problem.  Make sure you are using the 32 bit version as Window XP is 32 bit. (Unless you have a rare 64bit version).
If you are having problems with the installation, please add info.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
Le 2015-03-16 18:09, "geoff carver [via OSGeo.org]" <ml-node+s1560n5193731h22 at n6.nabble.com> a écrit :
	Has anyone been able to install any of the last several versions of QGIS on
WinXP?
If so, how?
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/QGIS-on-WinXP-tp5193731.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-on-WinXP-tp5193731p5193744.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150316/9d30278d/attachment.html>
