[Qgis-user] live tracking problem
Randal Hale
rjhale at northrivergeographic.com
Tue Mar 17 06:08:20 PDT 2015
Are you running as root or a local user when talking to the GPS?
Randy
On 03/17/2015 09:06 AM, Ramon AndiƱach wrote:
> I have the same symptom set for builds of both 2.8 ltr and master,
> so if anyone has suggestions, I'd be appreciative!
> (the windows box is too big to carry around, in case that gets suggested...)
> -ramon.
> On 17/03/2015, at 18:42 , Ramon AndiƱach wrote:
>> Hi,
>> I wondered if anyone had seen something like this?
>> I have 2 mint17 (ubuntu14.04) installs that both are failing to connect to either of my gps.
>> The gps are connecting and are being assigned a port.
>> I can observe communications.
>> I can use gpsbabel to access data on them.
>> (So I think the operating system is communicating with them fine)
>> If I try to connect them inside QGIS, after a 2 second wait (which is really, really short) QGIS tells me that it failed to connect to the gps.
>> I can not see any further information in the log or on the terminal.
>> There is no sign in the terminal that QGIS actually looked (in previous versions I can see which ports QGIS is trying in the terminal).
>> To complicate things, the same gps work perfectly on a win7 install (standalone or osgeo4w).
>> Has anyone else seen this?
>> Are there any pointers?
>> At this point I've.
>> Updated everything in sight.
>> Uninstalled/reinstalled
>> Uninstalled/removed .qgis2/reinstalled
>> uninstalled/swapped repositaries/reinstalled
>> and am currently compiling master to see if that helps.
>> -ramon.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
