[Qgis-user] live tracking problem
Ramon Andiñach
custard at westnet.com.au
Tue Mar 17 06:50:17 PDT 2015
Just in case I have not been clear.
1. My problem is with live tracking, not loading gpx files.
2. These gps were working in 2.6 (and earlier) for this task on these computers.
-ramon.
On 17/03/2015, at 21:06 , Ramon Andiñach wrote:
> I have the same symptom set for builds of both 2.8 ltr and master,
> so if anyone has suggestions, I'd be appreciative!
> (the windows box is too big to carry around, in case that gets suggested...)
> -ramon.
> On 17/03/2015, at 18:42 , Ramon Andiñach wrote:
>> Hi,
>> I wondered if anyone had seen something like this?
>> I have 2 mint17 (ubuntu14.04) installs that both are failing to connect to either of my gps.
>> The gps are connecting and are being assigned a port.
>> I can observe communications.
>> I can use gpsbabel to access data on them.
>> (So I think the operating system is communicating with them fine)
>> If I try to connect them inside QGIS, after a 2 second wait (which is really, really short) QGIS tells me that it failed to connect to the gps.
>> I can not see any further information in the log or on the terminal.
>> There is no sign in the terminal that QGIS actually looked (in previous versions I can see which ports QGIS is trying in the terminal).
>> To complicate things, the same gps work perfectly on a win7 install (standalone or osgeo4w).
>> Has anyone else seen this?
>> Are there any pointers?
>> At this point I've.
>> Updated everything in sight.
>> Uninstalled/reinstalled
>> Uninstalled/removed .qgis2/reinstalled
>> uninstalled/swapped repositaries/reinstalled
>> and am currently compiling master to see if that helps.
>> -ramon.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
