[Qgis-user] Customised attributes form
Matthias Kuhn matthias.kuhn at gmx.ch
Wed Mar 18 01:39:37 PDT 2015
Hi maxx,
On 03/17/2015 11:37 PM, emmexx wrote:
> Il 03/13/2015 10:50 AM, Matthias Kuhn scrisse:
>> Create a python plugin that registers a custom widget like the one in
>> the referenced blog post.
> Following your tips I created a plugin that registers a tree widget.
> And following the tutorial that you linked I was able to add a
> parameter to set the layer that the treewidget should use as a model
> (sort of) for data.
> There's only one glitch. I expected that that parameter would be saved
> when saving the project and loaded when opening it. But that is not
> the case.
> class TreeWidgetWrapperFactory( QgsEditorWidgetFactory ):
>   def readConfig( self, elem, layer, idx ):
>     """ Read a config object from an XML element """
>     pdb.set_trace()
>     config = dict()
>     config['MyTreeWidget'] = elem.attribute( 'MyTreeWidget' )
>     return config
> The readConfig function never runs. I don't understand what could be
> wrong because I copied and pasted the tutorial code for that class and
> changed only the name of the parameter where to save the configuration
> ("MyTreeWidget" instead of "rule".)
I tested and it is not your fault.
It's about the python bindings that seem not to support certain C++
constructs (in particular private virtual methods).
I have just pushed a fix to master, so if you are working with that your
code should run fine now (or with the next nightly).
This can also be backported to 2.8.2.
I would appreciate a short feedback if it also workd for you.
Matthias
