[Qgis-user] Problem installing QGIS 2.8 in Fedora 20
weatherman21 at nc.rr.com weatherman21 at nc.rr.com
Wed Mar 18 08:06:03 PDT 2015
When I attempt to install QGIS 2.8 on Fedora 20 from the QGIS download page, I get the following error message in the terminal:
Error: Package: qgis-mapserver-2.6.0-1.fc20.x86_64 (qgis)
           Requires: libqgis_analysis.so.2.6.0()(64bit)
           Available: qgis-2.6.0-1.fc20.x86_64 (qgis)
           Available: qgis-2.0.1-6.fc20.i686 (fedora)
               Not found
           Available: qgis-2.0.1-7.fc20.i686 (updates)
               Not found
           Installing: qgis-2.8.1-8.fc20.x86_64 (qgis)
              ~libqgis_analysis.so.2.8.1()(64bit)
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
I tried both of its suggestions, but it did not work.  I even tried uninstalling QGIS 2.6 before and still did not work.
Any solutions?
Jacob
