[Qgis-user] DB Manager in QGIS 2.8
David Fawcett david.fawcett at gmail.com
Wed Mar 18 20:25:30 PDT 2015
Thanks for the response Alexandre.
Here is the query:
SELECT fires.id, fires.inci_no, fires.descript, fires.geom
FROM lab.mpls_fires_2014 fires
INNER JOIN lab.mpls_lakes lakes
      ON ST_DWITHIN(fires.geom, lakes.geom, 1000)
When I add ST_GEOMETRYTYPE(fires.geom) to the query, the value is
St_MultiPoint for all records.
David.
On Wed, Mar 18, 2015 at 5:26 PM, Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Can you please show your sql query?
> Notice that if your query result in different geometries, qgis won't be
> able to choose a geometry type for the layer. I advice you to Check your
> results with St_GeometryType().
> Best regards,
> Alexandre Neto
> Em 18/03/2015 18:52, "David Fawcett" <david.fawcett at gmail.com> escreveu:
>> I am running QGIS 2.8.1 on OSX 10.9.5 using William's binaries.
>> The DB Manager plugin is at 0.1.20.
>> I can load layers into PostGIS using the DB Manager plugin, and I can use
>> the SQL window to execute a spatial query intersecting two tables.  But,
>> when I check the box to load the query result as a layer, fill out the
>> controls, and hit Load Now!, the layer isn't added.
>> I get the little black and white 'thinking beachball', but nothing else
>> happens.
>> Can anyone else confirm this?  If so, I can file an issue.
>> David.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150318/7b86c774/attachment.html>
