[Qgis-user] Lables in Composer
Richard McDonnell
richard.mcdonnell at opw.ie
Fri Mar 20 06:06:54 PDT 2015
Thanks for the reply,
I have used the map rotation option within the composer, but the layer
text also rotates, which is what I am trying to avoid.
An example of what I am on about would be where you have a Label layer,
with your text horizontal (on Map Canvas).
When you rotate the map in the composer, the text rotates also, what I
was hoping for is the option to set two rotations for the test, one in
the Map Canvas for viewing and editing and the other in the Composer for
Printing.
Regards,
Richard.
On 06/03/2015 18:11, Fred Lali wrote:
> Richard, go to angle in the composer, item properties, click the drop
> down at field name angle,n choose your preferred angle. Also make sure
> you lock the map layer so the text or any changes you make in the
> composer, doesn't affect the map layer n vice versa
> Thanks
> For God and My Country
> Consultant in: GIS,Forestry and Environment @ Earth Consult(U) Ltd.
> Rotarian at RC. Bweyogerere Namboole
> Mob: 0772/0752-841118
> Sent from Lumia Windows phone
> From: Richard McDonnell <mailto:richard.mcdonnell at opw.ie>
> Sent: âEURZ(06/âEURZ(03/âEURZ(2015 18:01
> To: Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Lables in Composer
> I was wondering if anyone knows of a way to auto Rotate text in Composer?
> I have a Map, which needs to be rotated to Print out on A4, having North
> at an angle, which means all my horizontal text is skewed in composer.
> I have at present added additional fields to allow for Label
> Relocation and rotation, which gets me over the issue in the meantime,
> It does of course skew the text in the canvas.
> It would be nice if there was a way in Composer to select these field
> values, this would leave the Text in the Canvas as is, and rotate it in
> the composer.
> If this is not available yet, maybe it could be added in a future update.
> Regards,
> Richard McDonnell
> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
> OPW - Looking to the future - Caring for the past
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150320/41efebda/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150320/41efebda/attachment.vcf>
