[Qgis-user] QGS project file clean-up?
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri Mar 20 14:19:19 PDT 2015
Yup,
I have found multiple ghost layers in my project.  Never caused a problem though.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
Le 2015-03-20 14:53, "Andre Joost [via OSGeo.org]" <ml-node+s1560n5194678h79 at n6.nabble.com> a écrit :
	Am 20.03.2015 um 19:43 schrieb magerlin:
> Am I the only one experiencing this?:
> When opening a saved QGS project file I have several times (also with older
> versions of Qgis) got messages like "Loading layer xxx" even though the
> layer xxx has previously been removed from the project? It has once been
> there, but I have right clicked and chosen remove (and saved).
> Opening the QGS file (in the recommendable free  Foxe xml-editor
> < http://www.firstobject.com/dn_editor.htm >  ) I can find this even though
> the layer has been removed:
> In the actual case the problem is a WFS layer - I am not sure whether the
> problem only concerns this type of layers.
It might be that styling or snapping information is still stored in the
project file.
Saving all styles to files and creating a new project file with the
datasources and style files should remove those traces, but I have not
yet had the need to do that.
Greetings,
André Joost
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/QGS-project-file-clean-up-tp5194674p5194678.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGS-project-file-clean-up-tp5194674p5194722.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150320/742a36bb/attachment.html>
