[Qgis-user] Layer doesn't change export to pdf
Alex Mandel
tech_dev at wildintellect.com
Sun Mar 22 19:06:53 PDT 2015
On 03/22/2015 02:15 PM, Chris House wrote:
> Hi all,
> This is my first email and I'm not 100% on protocol.
> I exported to a pdf from print composer. One of the layers were
> symbololized using inverted shapeburst polygons. After the first export I
> changed the starting color of the shapeburst. The next export reflected
> other changes to the map but not the starting color of the shapeburst.
> After exporting to jpg the color change was reflected. Any help would be
> appreciated!
> Thanks!
> Chris
Try the rasterize export option(It's a check box somewhere in the
composer). Some types of symbolization are not inherently supported by
pdf (color gradients in vectors being one of those).
Thanks,
Alex
