[Qgis-user] update "processing" plugin
Alain Gauthier
alain.gauthier at eaucea.fr
Wed Mar 25 02:51:21 PDT 2015
Hi Werner,
thank you for your quick answer, I understand your point of view of
updating QGIS.
As I have no time at the moment to update the tools I developped, I will
simply uninstall the last update of "processing".
Still the problem remains : "processing" metadata file should indicate
that the minimum version of this update is for a newer QGIS like 2.6...
Regards
Alain
Le 25/03/2015 10:26, Werner Macho a écrit :
> Hi!
> Just as a guess I'd say that 2.2 is rather old already.. Is an update
> to 2.4 possible (better 2.6, best 2.8) ;)
> regards
> Werner
> On Wed, Mar 25, 2015 at 10:19 AM, AlainG <alain.gauthier at eaucea.fr> wrote:
>> Hello,
>> I failed to install the new version of the plugin "processing" using the
>> QGIS plugin installation interface.
>> My Qgis installation is the following :
>> - QGIS 2.2.0-Valmeira (32 bits).
>> - OS : windows 7 pro - 64 bits.
>> Does anyone has this problem (I need to work with this version of QGIS) ?
>> Thank you
>> Alain
>> PS :part of th error message is
>> \Users\Alain\.qgis2-32/python/plugins\processing\algs\qgis\ui\FieldsMappingPanel.py",
>> line 34, in
>> from qgis.gui import QgsFieldExpressionWidget
>> ImportError: cannot import name QgsFieldExpressionWidget
>> Version de Python :
>> 2.7.4 (default, Apr 6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
>> Version de QGIS :
>> 2.2.0-Valmiera Valmiera, c3a2817
>> Alain Gauthier
>> View this message in context: http://osgeo-org.1560.x6.nabble.com/update-processing-plugin-tp5195325.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
