[Qgis-user] Question Install QGIS 2.8.1 - 64bit while QGIS 2.6.0 32bit still installed
Andreas Neumann
a.neumann at carto.net
Thu Mar 26 00:25:12 PDT 2015
Hi Tom,
Plugins should work smoothly between the 32bit and 64bit QGIS version,
as Python is a scripting language and compiled/recompiled when necessary
(the pyc versions are the binary versions of the python files). There is
more problems for plugins when moved between different QGIS versions,
esp. when there are API differences. You can also use the same
plugins/python files on other OS (fe. Linux and OSX) if the plugin
author did not use anything operating system dependent.
Greetings,
Andreas
On 26.03.2015 08:20, Leahy, Thomas A. wrote:
> Hello,
> I have been using QGIS 2.6.0 32bit and have just installed QGIS
> 2.8.1 64 bit.
> I noticed that the Proxy setting I had for QGIS 2.6.0 32bit show up
> in my QGIS 2.8.1 64bit version
> And
> The Plug-Ins I had in QGIS 2.6.0 32bit show up as already installed
> in my QGIS 2.8.1 64bit version.
> Is there going to be any problems with the Plug-Ins? Is there a
> difference between a Plug-In used by a 32bit version of QGIS vs a
> 64bit version?
> Also once I open files in version 2.8.1 will they not be able to be
> used with the 2.6.0 version?
> Thanks for your assistance.
> Best Regards,
> Tom Leahy
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150326/6007365d/attachment.html>
