[Qgis-user] Format GETFEATUREINFO request from QGISwebserver
Carles Vico Blanco carles.vico at geografos.org
Thu Mar 26 03:44:37 PDT 2015
Hi,qgis-users,
in the same way of my last question, about how format the GetFeatureInfo
request in QGISServer, some people tells me that QGIS Server runs in a
Mapserver architecture (its true?)
If that's true, Mapserver format the getfeatureinfo request with a *.map
file  that includes a TEMPLATE option with HTML styles. This option is
easier (for me I'm not a programmer) than the Python coding solution
Now, my problem is that, when I search in QGISServer, I can not find any
*.map file related about this.
Someone knows where is this *.map file? Or how works QGISServer to call the
mapserver .map file?
Thanks a lot!
Carles Vico
2015-03-20 12:21 GMT+01:00 Alessandro Pasotti <apasotti at gmail.com>:
> 2015-03-20 12:08 GMT+01:00 Carles Vico Blanco <carles.vico at geografos.org>:
> > Thank you very much for the reply, but I have a question of your answer.
> > When you say: "The latest release", I understand the QGIS 2.8, that's
> > correct? And then, I need to install the QGIS Server Python plugin on
> QGIS
> > Server, as you say here
> > http://www.itopen.it/qgis-server-python-plugins-ubuntu-setup/ , or It's
> no
> > necessary from the latest release of QGIS Desktop?
> > I'll try it and I tell you my result!
> > Thanks a lot!
> The article describe the setup to install the example HelloServer
> plugin and let it run on Ubuntu 14.04 server edition, you might find
> that useful to get started, you can also read the other 2 articles in
> the QGIS section of my website
> http://www.itopen.it/category/gis/qgis/qgis-server/
> You need to write a custom filter to modifiy GETFEATUREINFO request,
> if you examine the example plugin's code you will probably get some
> inspiration.
> Python plugins for QGIS Server are available with QGIS >= 2.8
> One of my tasks for the next HF is to add a "Server" section to the
> plugins official repository, if you develop something re-usable, don't
> forget to upload the plugin when it's done.
> Happy coding :)
> Alessandro Pasotti
> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150326/97a869a3/attachment.html>
