[Qgis-user] Fwd: Plugin "color a map" alternative?
Joris Hintjens
jorishin at gmail.com
Tue Mar 31 12:33:57 PDT 2015
> Thanks,Nyall, but "the computer says nooo!”
> error message:
> “plugin does not work , invalid syntax”
> I am illiterate when it comes to coding, so We’ll need help from the community.
> Joris
>> Op 31-mrt.-2015, om 20:21 heeft Nyall Dawson <nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>> het volgende geschreven:
>> On 1 Apr 2015 1:30 am, "Joris Hintjens" <jorishin at gmail.com <mailto:jorishin at gmail.com>> wrote:
>> > Hello,
>> > In the past, I used the plugin “color a map”, to color polygons is such a way that no 2 adjacent polygons hd the same fill color. This plugin does not work anymore is QGIS 2.x. Any alternatives around?
>> Here's a forked version of the old topocolour plugin, which does the same:
>> https://github.com/nyalldawson/topocolour <https://github.com/nyalldawson/topocolour>
>> It's not in the QGIS plugin catalog because it comes with absolutely no support ;) (I'm happy for someone to take over this if they're interested in packaging it up properly and handling maintenance).
>> That said, it works in QGIS >= 2.0 and has numerous improvements to the coloring algorithm.
>> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150331/b9274197/attachment.html>
