[Qgis-user] Add mssql non-geometric tables
Nathan Woodrow madmanwoo at gmail.com
Sun May 3 22:32:55 PDT 2015
Hey Peter,
Do you have a primary key on the table, or a column that is a int which is
unique?
Regards,
Nathan
On Mon, 4 May 2015 at 15:31 Peter Schürch <p.schuerch at meierpartner.ch>
wrote:
> Hi James
> Unfortunately the error message is a lot less specific as I thought...
> QGIS complains (in german, sorry) that the layer is invalid...
> Layer ist ungültig: Der Layer dbname='geosfer' host=meiwes03
> estimatedmetadata=true srid=0 table="dbo"."Borehole_Kind" sql= ist ungültig
> und kann der Karte nicht hinzugefügt werden
> This brings me back to the original question: what makes a flat table
> valid for QGIS? Is there any meta information needed somewhere?
> Hopefully you can make some sense of this.
> Cheers, Peter
> Von: James Wood [mailto:jwood911 at gmail.com]
> Gesendet: Samstag, 2. Mai 2015 16:22
> An: Peter Schürch
> Betreff: Re: [Qgis-user] Add mssql non-geometric tables
> Hey Peter,
> Yes, the problem is a little clearer now, thanks. When adding what we
> refer to here as a "flat table" (i.e., no geometry), it always just adds as
> a table object, so I've never seen that error before. The exact error
> message would be helpful. Also, what version of SQL Server are you running?
> James
> Sent from my iPhone
> On May 2, 2015, at 04:01, Peter Schürch <p.schuerch at meierpartner.ch>
> wrote:
> Hi James
> Thanks for getting back to me.
> I'using Wien too.
> The database connection is established. I can add existing geometry layers
> from the DB to the qgis project. I can also add new layers to the DB (e.g.
> A shape). So no fundamental problem with the DB.
> My problem is the following.
> I have defined a table in the DB without geometries, just numeric data. I
> can see it in the qgis browser but when i try to add it to my project i get
> an error saying that it is missing a crs. So i guess there is some meta
> info missing somewhere, but i wonder where and whether it has something to
> do with the metadata table 'geometry_colums' required for spatial layers. I
> need to look up the exact error message when I'm back in the office.
> Hope this is a little clearer now :-)
> Regards.
> Peter
> Meier und Partner AG
> Freiestrasse 26
> 8570 Weinfelden
> www.meierpartner.ch
> T +41 71 626 5115
> Am 01.05.2015 um 02:34 schrieb "James Wood" <jwood911 at gmail.com>:
> Hey Peter. Did you get a response to your question? I may not be
> understanding exactly what you are trying to do, but if you go ahead and
> add your MSSQL instance and connect to the database, you will be presented
> with both spatial and non -spatial tables that you can add into the map.
> So, (not to patronize), if you go to Layer > Add Layer > Add MSSQL Spatial
> Layer, that will present a dialog where you can choose your instance from
> the drop down or create a new connection. The list of all available table
> objects will appear once you hit connect. I'm using 2.8 Wien.
> HTH and I haven't missed your question entirely.
> James
> Sent from my iPhone
> On Apr 30, 2015, at 13:55, Peter Schürch <p.schuerch at meierpartner.ch>
> wrote:
> Hi
> Does anybody know how to add a non-geometric table from an mssql database
> to a qgis project?
> Do I need to add it in the table "geometry_columns"? If yes what would be
> the appropriate attribute values there?
> Thanks
> Peter Schürch
> Freiestrasse 26
> 8570 Weinfelden
> www.meierpartner.ch
> T +41 71 626 5115
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150504/b912da2e/attachment.html>
