[Qgis-user] Raster file format
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon May 4 16:07:14 PDT 2015
Thanks!
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On May 4, 2015 07:55, "ves nikos [via OSGeo.org]" <ml-node+s1560n5203980h41 at n6.nabble.com> wrote:
	Tiff is a very robust format if used correctly. Read through gdal's
Creation Properties [0] and add as you see fit at "Save Raster layer
as.." dialog -> "Create Options"  sector
N
[0] http://www.gdal.org/frmt_gtiff.html On Sun, May 3, 2015 at 2:19 AM, Nicolas Cadieux
< [hidden email] > wrote:
> Thanks!
> www.archeotec.ca
> On May 2, 2015 14:43, Alex Mandel < [hidden email] > wrote:
>> Just add Deflate or LZW compression to your tif (both are loseless, JPG
>> is not). The output files will be 10%-50% the size of the original in
>> most cases.
>> See the following post for a comparison of settings.
>> http://linfiniti.com/2011/05/gdal-efficiency-of-various-compression-algorithms/ >>
>> Enjoy,
>> Alex
>> On 05/02/2015 07:36 AM, Nicolas Cadieux wrote:
>> > Hi,
>> > I will be making huge... (No HUGE) DEMs file in QGIS.  I usually use .tif or.tiff (not really sure what the real difference is) but they are large files.
>> > What would be the best Qgis raster format permitting both smaller disk storage, lossless compression and ease of analysis using the various Qgis plugins? Formats need to accept floats.  I only use one band.
>> > Thanks for the help.
>> > www.archeotec.ca
>> > _______________________________________________
>> > Qgis-user mailing list
>> > [hidden email]
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user >> >
> [hidden email]
> http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
[hidden email]
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Raster-file-format-tp5203852p5203980.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Raster-file-format-tp5203852p5204092.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150504/75fd7f40/attachment.html>
