[Qgis-user] Spatial Query with buffer?
David Fawcett david.fawcett at gmail.com
Wed May 6 08:50:43 PDT 2015
If you don't have an easy way to set up PostGIS, you could use QGIS to save
your data in a SpatiaLite database, and then write a spatial query against
that.
On Wed, May 6, 2015 at 10:42 AM, DelazJ <delazj at gmail.com> wrote:
> Hi,
> May be you can use the graphical modeler of Processing to design your
> process. Processing offers both spatial selection and buffer tools.
> 2015-05-06 17:08 GMT+02:00 Joris Hintjens <jorishin at gmail.com>:
>> All my data is in shape.
>> Have a look at postgis is on my urgent to do list. Never worked with
>> postgis until now
>> 2015-05-06 16:37 GMT+02:00 James Keener <jim at jimkeener.com>:
>>> What's your data source? If it's PostGIS a query could do that in a
>>> mostly straightforward way.
>>> Jim
>>> On May 6, 2015 10:32:38 AM EDT, Joris Hintjens <jorishin at gmail.com>
>>> wrote:
>>>> Hello,
>>>> I want to do a spatial query.
>>>> Which Polygones intersect with a series of points,... That is easy with
>>>> the spatial query plugin.
>>>> BUT: Which polygones intersect with a buffer of X around my points...
>>>> How can I do that without creating a new layer where I buffer my points?
>>>> My points are not static, they change often, so creating a buffer layer
>>>> would require also an update of the buffer layer. Too complicated (and
>>>> source of errors!) to my taste...
>>>> All suggestions welcome.
>>>> Joris
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150506/ea67a5ce/attachment.html>
