[Qgis-user] Spatial Query with buffer?
James Keener jim at jimkeener.com
Wed May 6 09:37:31 PDT 2015
Sorry about the extra H in your name.  I saw your email and didn't look
at your signature.
Jim
On 05/06/2015 11:50 AM, David Fawcett wrote:
> If you don't have an easy way to set up PostGIS, you could use QGIS to
> save your data in a SpatiaLite database, and then write a spatial query
> against that.
> On Wed, May 6, 2015 at 10:42 AM, DelazJ <delazj at gmail.com
> <mailto:delazj at gmail.com>> wrote:
>     Hi,
>     May be you can use the graphical modeler of Processing to design
>     your process. Processing offers both spatial selection and buffer tools.
>     2015-05-06 17:08 GMT+02:00 Joris Hintjens <jorishin at gmail.com
>     <mailto:jorishin at gmail.com>>:
>         All my data is in shape.
>         Have a look at postgis is on my urgent to do list. Never worked
>         with postgis until now
>         2015-05-06 16:37 GMT+02:00 James Keener <jim at jimkeener.com
>         <mailto:jim at jimkeener.com>>:
>             What's your data source? If it's PostGIS a query could do
>             that in a mostly straightforward way.
>             Jim
>             On May 6, 2015 10:32:38 AM EDT, Joris Hintjens
>             <jorishin at gmail.com <mailto:jorishin at gmail.com>> wrote:
>                 Hello,
>                 I want to do a spatial query.
>                 Which Polygones intersect with a series of points,...
>                 That is easy with the spatial query plugin.
>                 BUT: Which polygones intersect with a buffer of X around
>                 my points... How can I do that without creating a new
>                 layer where I buffer my points?
>                 My points are not static, they change often, so creating
>                 a buffer layer would require also an update of the
>                 buffer layer. Too complicated (and source of errors!) to
>                 my taste...
>                 All suggestions welcome.
>                 Joris
>                 Qgis-user mailing list
>                 Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>                 http://lists.osgeo.org/mailman/listinfo/qgis-user
>             Sent from my Android device with K-9 Mail. Please excuse my
>             brevity.
>         _______________________________________________
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150506/7e4b59a0/attachment.sig>
