[Qgis-user] problems running processing.runalg('qgis:voronoipolygons', <postgis-layer>), processing.runalg('qgis:importintopostgis', ...)
Marco Lechner - FOSSGIS e.V. marco.lechner at fossgis.de
Wed May 6 23:59:22 PDT 2015
question moved to qgis-developer at lists.osgeo.org
Am 07.05.2015 um 08:30 schrieb Marco Lechner - FOSSGIS e.V.:
> Hi,
> 1. i try to run qgis' voronoipolygons algorithm from processing
> toolbox in a python script (processing-script or standalone)
> For testing I loaded a shape and a postgis layer to a
> QgsMapLayerRegistry. I can sucessfully run
> processing.runalg('qgis:voronoipolygons', <shape-layer>, 0, outShpVec)
> but processing.runalg('qgis:voronoipolygons', <postgis-layer>, 0,
> outShpVec) fails (with exit code 137 :-( ). No message in debugging
> console in my IDE (PyCharm).
> Any idea or example why this does not work or how I can do further
> investigation?
> 2. I'm in trouble using the qgis:importintopostgis via script as well.
> It expects an Index of a registered postgis connection. How can I use
> this alg by passing the connection params directly or do I have to
> create an entry in QSettings() for that and how can I get the latest
> registered connection than?
> Thank you
> Marco
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150507/f8fcbe17/attachment.key>
