[Qgis-user] OSM data gaps
JOE LEMONNIER jlemonnier at mac.com
Fri May 8 13:55:05 PDT 2015
I've download the OSM data from Vector>open street map> download data. Then imported the topology from xml then exported to Spatialite specifying poly lines. When do this for the span of lower Manhattan in New York City, I get a beautiful set of map data that is unfortunately missing quite a few major streets. Exporting as polygons doesn't omit those streets from the map but I need the center lines. Importing the .osm file directly gives the same results of missing  streets. I've tried 4 times with same results.
What am I doing wrong
Sent from iPhone
Sent from iPhone
