[Qgis-user] OSM data gaps
Andre Joost andre+joost at nurfuerspam.de
Sat May 9 01:14:38 PDT 2015
Am 08.05.2015 um 22:55 schrieb JOE LEMONNIER:
> I've download the OSM data from Vector>open street map> download
> data. Then imported the topology from xml then exported to Spatialite
> specifying poly lines. When do this for the span of lower Manhattan
> in New York City, I get a beautiful set of map data that is
> unfortunately missing quite a few major streets. Exporting as
> polygons doesn't omit those streets from the map but I need the
> center lines. Importing the .osm file directly gives the same results
> of missing  streets. I've tried 4 times with same results.
> What am I doing wrong
I can replicate your error. Maybe the data is just too big and crashes
the importer. Unfortunately, you get no error message.
However, you can still use the downloaded .osm file which is complete.
As Anita suggests, you can use
ogr2ogr -f "SQLite" -dsco SPATIALITE=YES newyork.db ny.osm
or just drag and drop the .osm file into the legend, and select the
lines for importing. This needs quite some time, and you should save the
result to a shapefile for further use. Both methods use the GDAL osm
driver, hence contain the same amount of data (both 53607 lines from my
canvas extent instead of 37602 from the importer).
Using osm2pgsql, I get 59667 lines. Some incomplete multipolygon
relation members are treated differently in GDAL and osm2pgsql.
HTH,
André Joost
