[Qgis-user] Can't install QGIS due to unmet dependencies
Filipe Dias filipesdias at gmail.com
Sun May 10 08:17:29 PDT 2015
Thanks
Is there anyway of knowing when this will be fixed? Tomorrow is Monday and
I would like to know if I will be able to work on this computer on not...
Cheers
F.
On Sat, May 9, 2015 at 3:56 PM, João Gaspar <joao.f.r.gaspar at gmail.com>
wrote:
> Hi  Filipe.  I ask  the same thing in the qgis-dev list.
> http://osgeo-org.1560.x6.nabble.com/Linux-Mint-QGIS-2-8-1-stop-work-when-upgrading-to-GDAL-11-1-2-td5204949.html
> Regards
> João
>  Hi
> I'm trying to install QGIS from ubuntugis unstable and I'm getting this
> message after I type:
> sudo apt-get install qgis python-qgis
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
>  qgis : Depends: libgdal.so.1-1.11.1 but it is not installable
>         Recommends: qgis-plugin-grass but it is not going to be installed
>         Recommends: qgis-plugin-globe but it is not going to be installed
> Cheers
> F.
> Qgis-user mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5204967&i=0>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Can-t-install-QGIS-due-to-unmet-dependencies-tp5204967.html
>  To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h54 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=am9hb2ZyZ2FzcGFyQGdtYWlsLmNvbXw0MTI1MjY3fDE0NTE2NTI4NA==>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150510/9797c06c/attachment.html>
