[Qgis-user] Fwd: Re: Points in Polygon
Alex Mandel tech_dev at wildintellect.com
Fri May 15 22:35:37 PDT 2015
Please keep the conversation on list.
-------- Forwarded Message --------
Subject: Re: [Qgis-user] Points in Polygon
Date: Fri, 15 May 2015 16:44:13 -0400
To: tech at wildintellect.com
​Alex,
I tried multiple polygons and points and still got the same results. Please
the attached .dmp file converted to txt.
Thank you for the help.
Joseph
On Fri, May 15, 2015 at 3:24 PM, Alex Mandel <tech_dev at wildintellect.com>
wrote:
> Does it matter what Point and Polygon layers are used (e.g. can you try
> some others, maybe even handmade 1 polygon 2 points).
> Also attach or post to the internet the .dmp file mentioned in that
> image. That is the error log.
> Thanks,
> Alex
> On 05/15/2015 12:17 PM, Joseph Sloop wrote:
> > To All:
> > I am running the 'Points in Polygon' process in QGIS 2.8.2 version and
> > every time I run the process I get this error:
> > ​[image: Inline image 1]
> > Once you click ok, QGIS shuts down. Any thoughts or suggestions?
> > Cheers,
> > Joseph​
> > _____________________________
> > Joseph Sloop
> > PhD Candidate
> > University of North Carolina at Greensboro
> > Department of Geography
> > jbsloop at uncg.edu
Joseph Sloop
PhD Candidate
jbsloop at uncg.edu
Dump Summary
Dump File:	qgis-20150515-151339-7224-1544-1b929ef.dmp : D:\Downloads\qgis-20150515-151339-7224-1544-1b929ef.dmp
Last Write Time:	5/15/2015 4:35:53 PM
Process Name:	qgis-bin.exe : C:\Program Files\QGIS Wien\bin\qgis-bin.exe
Process Architecture:	x64
Exception Code:	0xC0000005
Exception Information:	The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
Heap Information:	Not Present
System Information
OS Version:	6.1.7601
CLR Version(s):
Modules
Module Name	Module Path	Module Version
qgis-bin.exe	C:\Program Files\QGIS Wien\bin\qgis-bin.exe	0.0.0.0
ntdll.dll	C:\Windows\System32\ntdll.dll	6.1.7601.18798
kernel32.dll	C:\Windows\System32\kernel32.dll	6.1.7601.18798
KERNELBASE.dll	C:\Windows\System32\KERNELBASE.dll	6.1.7601.18798
shell32.dll	C:\Windows\System32\shell32.dll	6.1.7601.18762
msvcrt.dll	C:\Windows\System32\msvcrt.dll	7.0.7601.17744
shlwapi.dll	C:\Windows\System32\shlwapi.dll	6.1.7601.17514
gdi32.dll	C:\Windows\System32\gdi32.dll	6.1.7601.18577
user32.dll	C:\Windows\System32\user32.dll	6.1.7601.17514
lpk.dll	C:\Windows\System32\lpk.dll	6.1.7601.18768
usp10.dll	C:\Windows\System32\usp10.dll	1.626.7601.18454
qwt5.dll	C:\Program Files\QGIS Wien\bin\qwt5.dll	5.2.3.0
QtGui4.dll	C:\Program Files\QGIS Wien\bin\QtGui4.dll	4.8.5.0
comdlg32.dll	C:\Windows\System32\comdlg32.dll	6.1.7601.17514
comctl32.dll	C:\Windows\winsxs\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18201_none_a4d3b9377117c3df\comctl32.dll	5.82.7601.18201
advapi32.dll	C:\Windows\System32\advapi32.dll	6.1.7601.18247
sechost.dll	C:\Windows\System32\sechost.dll	6.1.7600.16385
rpcrt4.dll	C:\Windows\System32\rpcrt4.dll	6.1.7601.18532
oleaut32.dll	C:\Windows\System32\oleaut32.dll	6.1.7601.18640
ole32.dll	C:\Windows\System32\ole32.dll	6.1.7601.17514
imm32.dll	C:\Windows\System32\imm32.dll	6.1.7600.16385
msctf.dll	C:\Windows\System32\msctf.dll	6.1.7601.18731
winmm.dll	C:\Windows\System32\winmm.dll	6.1.7600.16385
winspool.drv	C:\Windows\System32\winspool.drv	6.1.7601.17514
libpng16.dll	C:\Program Files\QGIS Wien\bin\libpng16.dll	0.0.0.0
zlib1.dll	C:\Program Files\QGIS Wien\bin\zlib1.dll	1.2.8.0
msvcr100.dll	C:\Program Files\QGIS Wien\bin\msvcr100.dll	10.0.40219.1
QtCore4.dll	C:\Program Files\QGIS Wien\bin\QtCore4.dll	4.8.5.0
ws2_32.dll	C:\Windows\System32\ws2_32.dll	6.1.7601.17514
nsi.dll	C:\Windows\System32\nsi.dll	6.1.7600.16385
msvcp100.dll	C:\Program Files\QGIS Wien\bin\msvcp100.dll	10.0.40219.1
QtSql4.dll	C:\Program Files\QGIS Wien\bin\QtSql4.dll	4.8.5.0
libpq.dll	C:\Program Files\QGIS Wien\bin\libpq.dll	9.2.4.13228
ssleay32.dll	C:\Program Files\QGIS Wien\bin\ssleay32.dll	1.0.1.7
libeay32.dll	C:\Program Files\QGIS Wien\bin\libeay32.dll	1.0.1.7
msvcr90.dll	C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c\msvcr90.dll	9.0.30729.4940
wsock32.dll	C:\Windows\System32\wsock32.dll	6.1.7600.16385
secur32.dll	C:\Windows\System32\secur32.dll	6.1.7601.18798
sspicli.dll	C:\Windows\System32\sspicli.dll	6.1.7601.18798
Wldap32.dll	C:\Windows\System32\Wldap32.dll	6.1.7601.17514
odbc32.dll	C:\Windows\System32\odbc32.dll	6.1.7601.17514
QtWebKit4.dll	C:\Program Files\QGIS Wien\bin\QtWebKit4.dll	4.9.4.0
sqlite3.dll	C:\Program Files\QGIS Wien\bin\sqlite3.dll	0.0.0.0
version.dll	C:\Windows\System32\version.dll	6.1.7600.16385
QtNetwork4.dll	C:\Program Files\QGIS Wien\bin\QtNetwork4.dll	4.8.5.0
gdal111.dll	C:\Program Files\QGIS Wien\bin\gdal111.dll	1.11.2.0
ogdi.dll	C:\Program Files\QGIS Wien\bin\ogdi.dll	0.0.0.0
expat.dll	C:\Program Files\QGIS Wien\bin\expat.dll	0.0.0.0
proj.dll	C:\Program Files\QGIS Wien\bin\proj.dll	0.0.0.0
xerces-c_3_1.dll	C:\Program Files\QGIS Wien\bin\xerces-c_3_1.dll	3.1.1.0
jpeg.dll	C:\Program Files\QGIS Wien\bin\jpeg.dll	0.0.0.0
netcdf.dll	C:\Program Files\QGIS Wien\bin\netcdf.dll	0.0.0.0
libcurl.dll	C:\Program Files\QGIS Wien\bin\libcurl.dll	7.31.0.0
normaliz.dll	C:\Windows\System32\normaliz.dll	6.1.7600.16385
geotiff.dll	C:\Program Files\QGIS Wien\bin\geotiff.dll	0.0.0.0
libtiff.dll	C:\Program Files\QGIS Wien\bin\libtiff.dll	0.0.0.0
jpeg12.dll	C:\Program Files\QGIS Wien\bin\jpeg12.dll	0.0.0.0
spatialite.dll	C:\Program Files\QGIS Wien\bin\spatialite.dll	0.0.0.0
geos_c.dll	C:\Program Files\QGIS Wien\bin\geos_c.dll	0.0.0.0
freexl.dll	C:\Program Files\QGIS Wien\bin\freexl.dll	0.0.0.0
iconv.dll	C:\Program Files\QGIS Wien\bin\iconv.dll	0.0.0.0
libxml2.dll	C:\Program Files\QGIS Wien\bin\libxml2.dll	0.0.0.0
libmysql.dll	C:\Program Files\QGIS Wien\bin\libmysql.dll	6.1.0.0
hdf5.dll	C:\Program Files\QGIS Wien\bin\hdf5.dll	0.0.0.0
szip.dll	C:\Program Files\QGIS Wien\bin\szip.dll	0.0.0.0
openjp2.dll	C:\Program Files\QGIS Wien\bin\openjp2.dll	0.0.0.0
qgis_core.dll	C:\Program Files\QGIS Wien\apps\qgis\bin\qgis_core.dll	0.0.0.0
QtXml4.dll	C:\Program Files\QGIS Wien\bin\QtXml4.dll	4.8.5.0
QtSvg4.dll	C:\Program Files\QGIS Wien\bin\QtSvg4.dll	4.8.5.0
spatialindex-64.dll	C:\Program Files\QGIS Wien\bin\spatialindex-64.dll	0.0.0.0
msvcp120.dll	C:\Windows\System32\msvcp120.dll	12.0.21005.1
msvcr120.dll	C:\Windows\System32\msvcr120.dll	12.0.21005.1
qgis_gui.dll	C:\Program Files\QGIS Wien\apps\qgis\bin\qgis_gui.dll	0.0.0.0
qscintilla2.dll	C:\Program Files\QGIS Wien\bin\qscintilla2.dll	0.0.0.0
qgis_analysis.dll	C:\Program Files\QGIS Wien\apps\qgis\bin\qgis_analysis.dll	0.0.0.0
dbghelp.dll	C:\Windows\System32\dbghelp.dll	6.1.7601.17514
nvinitx.dll	C:\Windows\System32\nvinitx.dll	9.18.13.2762
odbcint.dll	C:\Windows\System32\odbcint.dll	6.1.7600.16385
uxtheme.dll	C:\Windows\System32\uxtheme.dll	6.1.7600.16385
dwmapi.dll	C:\Windows\System32\dwmapi.dll	6.1.7600.16385
CRYPTBASE.dll	C:\Windows\System32\CRYPTBASE.dll	6.1.7600.16385
userenv.dll	C:\Windows\System32\userenv.dll	6.1.7601.17514
profapi.dll	C:\Windows\System32\profapi.dll	6.1.7600.16385
qgif4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\imageformats\qgif4.dll	4.8.5.0
qico4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\imageformats\qico4.dll	4.8.5.0
qjpeg4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\imageformats\qjpeg4.dll	4.8.5.0
qmng4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\imageformats\qmng4.dll	4.8.5.0
qsvg4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\imageformats\qsvg4.dll	4.8.5.0
qtga4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\imageformats\qtga4.dll	4.8.5.0
qtiff4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\imageformats\qtiff4.dll	4.8.5.0
qsvgicon4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\iconengines\qsvgicon4.dll	4.8.5.0
qgenericbearer4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\bearer\qgenericbearer4.dll	4.8.5.0
IPHLPAPI.DLL	C:\Windows\System32\IPHLPAPI.DLL	6.1.7601.17514
winnsi.dll	C:\Windows\System32\winnsi.dll	6.1.7600.16385
dhcpcsvc.dll	C:\Windows\System32\dhcpcsvc.dll	6.1.7600.16385
dhcpcsvc6.DLL	C:\Windows\System32\dhcpcsvc6.DLL	6.1.7600.16385
qnativewifibearer4.dll	C:\Program Files\QGIS Wien\apps\Qt4\plugins\bearer\qnativewifibearer4.dll	4.8.5.0
wlanapi.dll	C:\Windows\System32\wlanapi.dll	6.1.7600.16385
wlanutil.dll	C:\Windows\System32\wlanutil.dll	6.1.7600.16385
coordinatecaptureplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\coordinatecaptureplugin.dll	0.0.0.0
delimitedtextprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\delimitedtextprovider.dll	0.0.0.0
dxf2shpconverterplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\dxf2shpconverterplugin.dll	0.0.0.0
evis.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\evis.dll	0.0.0.0
gdalprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\gdalprovider.dll	0.0.0.0
gdal_ECW_JP2ECW.dll	C:\Program Files\QGIS Wien\bin\gdalplugins\gdal_ECW_JP2ECW.dll	0.0.0.0
NCSEcw.dll	C:\Program Files\QGIS Wien\bin\NCSEcw.dll	5.0.1.1346
crypt32.dll	C:\Windows\System32\crypt32.dll	6.1.7601.18277
msasn1.dll	C:\Windows\System32\msasn1.dll	6.1.7601.17514
imagehlp.dll	C:\Windows\System32\imagehlp.dll	6.1.7601.18288
gdal_GEOR.dll	C:\Program Files\QGIS Wien\bin\gdalplugins\gdal_GEOR.dll	0.0.0.0
oci.dll	C:\Program Files\QGIS Wien\bin\oci.dll	12.1.0.0
psapi.dll	C:\Windows\System32\psapi.dll	6.1.7600.16385
gdal_MG4Lidar.dll	C:\Program Files\QGIS Wien\bin\gdalplugins\gdal_MG4Lidar.dll	0.0.0.0
lti_lidar_dsdk.dll	C:\Program Files\QGIS Wien\bin\lti_lidar_dsdk.dll	1.1.1.3422
gdal_MrSID.dll	C:\Program Files\QGIS Wien\bin\gdalplugins\gdal_MrSID.dll	0.0.0.0
lti_dsdk.dll	C:\Program Files\QGIS Wien\bin\lti_dsdk.dll	8.5.0.3422
georefplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\georefplugin.dll	0.0.0.0
gsl.dll	C:\Program Files\QGIS Wien\bin\gsl.dll	0.0.0.0
cblas.dll	C:\Program Files\QGIS Wien\bin\cblas.dll	0.0.0.0
globeplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\globeplugin.dll	0.0.0.0
QtOpenGL4.dll	C:\Program Files\QGIS Wien\bin\QtOpenGL4.dll	4.8.5.0
opengl32.dll	C:\Windows\System32\opengl32.dll	6.1.7600.16385
glu32.dll	C:\Windows\System32\glu32.dll	6.1.7600.16385
ddraw.dll	C:\Windows\System32\ddraw.dll	6.1.7600.16385
dciman32.dll	C:\Windows\System32\dciman32.dll	6.1.7601.18768
setupapi.dll	C:\Windows\System32\setupapi.dll	6.1.7601.17514
cfgmgr32.dll	C:\Windows\System32\cfgmgr32.dll	6.1.7601.17514
devobj.dll	C:\Windows\System32\devobj.dll	6.1.7600.16385
osg97-osgDB.dll	C:\Program Files\QGIS Wien\bin\osg97-osgDB.dll	3.1.7.97
osg97-osg.dll	C:\Program Files\QGIS Wien\bin\osg97-osg.dll	3.1.7.97
ot12-OpenThreads.dll	C:\Program Files\QGIS Wien\bin\ot12-OpenThreads.dll	2.6.0.12
osg97-osgUtil.dll	C:\Program Files\QGIS Wien\bin\osg97-osgUtil.dll	3.1.7.97
osg97-osgGA.dll	C:\Program Files\QGIS Wien\bin\osg97-osgGA.dll	3.1.7.97
osg97-osgQt.dll	C:\Program Files\QGIS Wien\bin\osg97-osgQt.dll	3.1.7.97
osg97-osgViewer.dll	C:\Program Files\QGIS Wien\bin\osg97-osgViewer.dll	3.1.7.97
osg97-osgText.dll	C:\Program Files\QGIS Wien\bin\osg97-osgText.dll	3.1.7.97
osgEarth.dll	C:\Program Files\QGIS Wien\bin\osgEarth.dll	0.0.0.0
osg97-osgTerrain.dll	C:\Program Files\QGIS Wien\bin\osg97-osgTerrain.dll	3.1.7.97
osg97-osgShadow.dll	C:\Program Files\QGIS Wien\bin\osg97-osgShadow.dll	3.1.7.97
gdal110.dll	C:\Program Files\QGIS Wien\bin\gdal110.dll	1.10.1.0
osg97-osgManipulator.dll	C:\Program Files\QGIS Wien\bin\osg97-osgManipulator.dll	3.1.7.97
osgEarthUtil.dll	C:\Program Files\QGIS Wien\bin\osgEarthUtil.dll	0.0.0.0
osgEarthFeatures.dll	C:\Program Files\QGIS Wien\bin\osgEarthFeatures.dll	0.0.0.0
osgEarthSymbology.dll	C:\Program Files\QGIS Wien\bin\osgEarthSymbology.dll	0.0.0.0
osgEarthAnnotation.dll	C:\Program Files\QGIS Wien\bin\osgEarthAnnotation.dll	0.0.0.0
osg97-osgSim.dll	C:\Program Files\QGIS Wien\bin\osg97-osgSim.dll	3.1.7.97
osgEarthQt.dll	C:\Program Files\QGIS Wien\bin\osgEarthQt.dll	0.0.0.0
gpsimporterplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\gpsimporterplugin.dll	0.0.0.0
gpxprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\gpxprovider.dll	0.0.0.0
grassplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\grassplugin.dll	0.0.0.0
qgisgrass.dll	C:\Program Files\QGIS Wien\apps\qgis\bin\qgisgrass.dll	0.0.0.0
libgrass_gis.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_gis.6.4.3.dll	0.0.0.0
libgrass_datetime.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_datetime.6.4.3.dll	0.0.0.0
libintl-8.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\bin\libintl-8.dll	0.18.2.0
libiconv-2.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\bin\libiconv-2.dll	1.14.0.0
libgrass_vect.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_vect.6.4.3.dll	0.0.0.0
libgrass_dbmibase.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_dbmibase.6.4.3.dll	0.0.0.0
libgrass_dbmiclient.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_dbmiclient.6.4.3.dll	0.0.0.0
libgrass_linkm.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_linkm.6.4.3.dll	0.0.0.0
libgrass_dgl.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_dgl.6.4.3.dll	0.0.0.0
libgrass_rtree.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_rtree.6.4.3.dll	0.0.0.0
libgrass_dig2.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_dig2.6.4.3.dll	0.0.0.0
libgrass_gproj.6.4.3.dll	C:\Program Files\QGIS Wien\apps\grass\grass-6.4.3\lib\libgrass_gproj.6.4.3.dll	0.0.0.0
grassprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\grassprovider.dll	0.0.0.0
grassrasterprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\grassrasterprovider.dll	0.0.0.0
heatmapplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\heatmapplugin.dll	0.0.0.0
interpolationplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\interpolationplugin.dll	0.0.0.0
memoryprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\memoryprovider.dll	0.0.0.0
mssqlprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\mssqlprovider.dll	0.0.0.0
offlineeditingplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\offlineeditingplugin.dll	0.0.0.0
ogrprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\ogrprovider.dll	0.0.0.0
ogr_OCI.dll	C:\Program Files\QGIS Wien\bin\gdalplugins\ogr_OCI.dll	0.0.0.0
ogr_SOSI.dll	C:\Program Files\QGIS Wien\bin\gdalplugins\ogr_SOSI.dll	0.0.0.0
oracleplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\oracleplugin.dll	0.0.0.0
oracleprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\oracleprovider.dll	0.0.0.0
owsprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\owsprovider.dll	0.0.0.0
postgresprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\postgresprovider.dll	0.0.0.0
rasterterrainplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\rasterterrainplugin.dll	0.0.0.0
roadgraphplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\roadgraphplugin.dll	0.0.0.0
qgis_networkanalysis.dll	C:\Program Files\QGIS Wien\apps\qgis\bin\qgis_networkanalysis.dll	0.0.0.0
spatialiteprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\spatialiteprovider.dll	0.0.0.0
spatialqueryplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\spatialqueryplugin.dll	0.0.0.0
spitplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\spitplugin.dll	0.0.0.0
topolplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\topolplugin.dll	0.0.0.0
wcsprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\wcsprovider.dll	0.0.0.0
wfsprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\wfsprovider.dll	0.0.0.0
wmsprovider.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\wmsprovider.dll	0.0.0.0
QtScript4.dll	C:\Program Files\QGIS Wien\bin\QtScript4.dll	4.8.5.0
zonalstatisticsplugin.dll	C:\Program Files\QGIS Wien\apps\qgis\plugins\zonalstatisticsplugin.dll	0.0.0.0
qgispython.DLL	C:\Program Files\QGIS Wien\apps\qgis\bin\qgispython.DLL	0.0.0.0
python27.dll	C:\Program Files\QGIS Wien\bin\python27.dll	2.7.5150.1013
sip.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\sip.pyd	0.0.0.0
QtCore.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\PyQt4\QtCore.pyd	0.0.0.0
QtGui.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\PyQt4\QtGui.pyd	0.0.0.0
_core.pyd	C:\Program Files\QGIS Wien\apps\qgis\python\qgis\_core.pyd	0.0.0.0
QtNetwork.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\PyQt4\QtNetwork.pyd	0.0.0.0
QtXml.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\PyQt4\QtXml.pyd	0.0.0.0
_gui.pyd	C:\Program Files\QGIS Wien\apps\qgis\python\qgis\_gui.pyd	0.0.0.0
Qsci.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\PyQt4\Qsci.pyd	0.0.0.0
multiarray.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\core\multiarray.pyd	0.0.0.0
umath.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\core\umath.pyd	0.0.0.0
_dotblas.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\core\_dotblas.pyd	0.0.0.0
libiomp5md.dll	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\core\libiomp5md.dll	5.0.2014.401
scalarmath.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\core\scalarmath.pyd	0.0.0.0
_compiled_base.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\lib\_compiled_base.pyd	0.0.0.0
lapack_lite.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\linalg\lapack_lite.pyd	0.0.0.0
_umath_linalg.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\linalg\_umath_linalg.pyd	0.0.0.0
fftpack_lite.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\fft\fftpack_lite.pyd	0.0.0.0
mtrand.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\numpy\random\mtrand.pyd	0.0.0.0
cryptsp.dll	C:\Windows\System32\cryptsp.dll	6.1.7600.16385
rsaenh.dll	C:\Windows\System32\rsaenh.dll	6.1.7600.16385
_ctypes.pyd	C:\Program Files\QGIS Wien\apps\Python27\DLLs\_ctypes.pyd	0.0.0.0
_gdal.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\osgeo\_gdal.pyd	0.0.0.0
_gdalconst.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\osgeo\_gdalconst.pyd	0.0.0.0
QtWebKit.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\PyQt4\QtWebKit.pyd	0.0.0.0
_hashlib.pyd	C:\Program Files\QGIS Wien\apps\Python27\DLLs\_hashlib.pyd	0.0.0.0
_socket.pyd	C:\Program Files\QGIS Wien\apps\Python27\DLLs\_socket.pyd	0.0.0.0
_ssl.pyd	C:\Program Files\QGIS Wien\apps\Python27\DLLs\_ssl.pyd	0.0.0.0
_path.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\matplotlib-1.3.1-py2.7-win-amd64.egg\matplotlib\_path.pyd	0.0.0.0
msvcp90.dll	C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c\msvcp90.dll	9.0.30729.4940
ft2font.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\matplotlib-1.3.1-py2.7-win-amd64.egg\matplotlib\ft2font.pyd	0.0.0.0
unicodedata.pyd	C:\Program Files\QGIS Wien\apps\Python27\DLLs\unicodedata.pyd	0.0.0.0
_png.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\matplotlib-1.3.1-py2.7-win-amd64.egg\matplotlib\_png.pyd	0.0.0.0
_imaging.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\PIL\_imaging.pyd	0.0.0.0
_cntr.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\matplotlib-1.3.1-py2.7-win-amd64.egg\matplotlib\_cntr.pyd	0.0.0.0
_image.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\matplotlib-1.3.1-py2.7-win-amd64.egg\matplotlib\_image.pyd	0.0.0.0
_delaunay.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\matplotlib-1.3.1-py2.7-win-amd64.egg\matplotlib\_delaunay.pyd	0.0.0.0
_tri.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\matplotlib-1.3.1-py2.7-win-amd64.egg\matplotlib\_tri.pyd	0.0.0.0
_backend_agg.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\matplotlib-1.3.1-py2.7-win-amd64.egg\matplotlib\backends\_backend_agg.pyd	0.0.0.0
_ogr.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\osgeo\_ogr.pyd	0.0.0.0
_osr.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\osgeo\_osr.pyd	0.0.0.0
_psycopg.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\psycopg2\_psycopg.pyd	0.0.0.0
_speedups.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\markupsafe-0.23-py2.7-win-amd64.egg\markupsafe\_speedups.pyd	0.0.0.0
pyexpat.pyd	C:\Program Files\QGIS Wien\apps\Python27\DLLs\pyexpat.pyd	0.0.0.0
nlaapi.dll	C:\Windows\System32\nlaapi.dll	6.1.7601.17964
NapiNSP.dll	C:\Windows\System32\NapiNSP.dll	6.1.7600.16385
pnrpnsp.dll	C:\Windows\System32\pnrpnsp.dll	6.1.7600.16385
mswsock.dll	C:\Windows\System32\mswsock.dll	6.1.7601.17514
dnsapi.dll	C:\Windows\System32\dnsapi.dll	6.1.7601.17570
winrnr.dll	C:\Windows\System32\winrnr.dll	6.1.7600.16385
wshbth.dll	C:\Windows\System32\wshbth.dll	6.1.7601.17514
mdnsNSP.dll	C:\Program Files\Bonjour\mdnsNSP.dll	3.0.0.10
win32api.pyd	C:\Program Files\QGIS Wien\apps\Python27\Lib\site-packages\win32\win32api.pyd	2.7.218.0
pywintypes27.dll	C:\Program Files\QGIS Wien\bin\pywintypes27.dll	2.7.218.0
apphelp.dll	C:\Windows\System32\apphelp.dll	6.1.7601.17514
RpcRtRemote.dll	C:\Windows\System32\RpcRtRemote.dll	6.1.7601.17514
clbcatq.dll	C:\Windows\System32\clbcatq.dll	2001.12.8530.16385
comctl32.dll	C:\Windows\winsxs\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\comctl32.dll	6.10.7601.17514
linkinfo.dll	C:\Windows\System32\linkinfo.dll	6.1.7600.16385
propsys.dll	C:\Windows\System32\propsys.dll	7.0.7601.17514
ntmarta.dll	C:\Windows\System32\ntmarta.dll	6.1.7600.16385
WindowsCodecs.dll	C:\Windows\System32\WindowsCodecs.dll	6.2.9200.17251
GROOVEEX.DLL	C:\Program Files\Microsoft Office\Office15\GROOVEEX.DLL	15.0.4569.1503
atl100.dll	C:\Windows\System32\atl100.dll	10.0.40219.325
msi.dll	C:\Windows\System32\msi.dll	5.0.7601.18493
GrooveIntlResource.dll	C:\Program Files\Microsoft Office\Office15\1033\GrooveIntlResource.dll	15.0.4569.1501
EhStorShell.dll	C:\Windows\System32\EhStorShell.dll	6.1.7600.16385
googledrivesync64.dll	C:\Program Files (x86)\Google\Drive\googledrivesync64.dll	1.21.9226.6034
msvcp90.dll	C:\Program Files (x86)\Google\Drive\Microsoft.VC90.CRT\msvcp90.dll	9.0.30729.6161
msvcr90.dll	C:\Program Files (x86)\Google\Drive\Microsoft.VC90.CRT\msvcr90.dll	9.0.30729.6161
cscui.dll	C:\Windows\System32\cscui.dll	6.1.7601.17514
cscdll.dll	C:\Windows\System32\cscdll.dll	6.1.7601.17514
cscapi.dll	C:\Windows\System32\cscapi.dll	6.1.7601.17514
ntshrui.dll	C:\Windows\System32\ntshrui.dll	6.1.7601.17755
srvcli.dll	C:\Windows\System32\srvcli.dll	6.1.7601.17514
slc.dll	C:\Windows\System32\slc.dll	6.1.7600.16385
mpr.dll	C:\Windows\System32\mpr.dll	6.1.7600.16385
drprov.dll	C:\Windows\System32\drprov.dll	6.1.7600.16385
winsta.dll	C:\Windows\System32\winsta.dll	6.1.7601.18540
ntlanman.dll	C:\Windows\System32\ntlanman.dll	6.1.7601.17514
davclnt.dll	C:\Windows\System32\davclnt.dll	6.1.7601.17514
davhlpr.dll	C:\Windows\System32\davhlpr.dll	6.1.7600.16385
wkscli.dll	C:\Windows\System32\wkscli.dll	6.1.7601.17514
netutils.dll	C:\Windows\System32\netutils.dll	6.1.7601.17514
cscobj.dll	C:\Windows\System32\cscobj.dll	6.1.7601.17514
wintrust.dll	C:\Windows\System32\wintrust.dll	6.1.7601.18205
wpdshext.dll	C:\Windows\System32\wpdshext.dll	6.1.7601.17514
GdiPlus.dll	C:\Windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18455_none_2b283fd671e9bf4d\GdiPlus.dll	6.1.7601.18455
shdocvw.dll	C:\Windows\System32\shdocvw.dll	6.1.7601.18222
ieframe.dll	C:\Windows\System32\ieframe.dll	11.0.9600.17631
api-ms-win-downlevel-advapi32-l1-1-0.dll	C:\Windows\System32\api-ms-win-downlevel-advapi32-l1-1-0.dll	6.2.9200.16492
api-ms-win-downlevel-shlwapi-l1-1-0.dll	C:\Windows\System32\api-ms-win-downlevel-shlwapi-l1-1-0.dll	6.2.9200.16492
api-ms-win-downlevel-user32-l1-1-0.dll	C:\Windows\System32\api-ms-win-downlevel-user32-l1-1-0.dll	6.2.9200.16492
api-ms-win-downlevel-shell32-l1-1-0.dll	C:\Windows\System32\api-ms-win-downlevel-shell32-l1-1-0.dll	6.2.9200.16492
api-ms-win-downlevel-version-l1-1-0.dll	C:\Windows\System32\api-ms-win-downlevel-version-l1-1-0.dll	6.2.9200.16492
api-ms-win-downlevel-normaliz-l1-1-0.dll	C:\Windows\System32\api-ms-win-downlevel-normaliz-l1-1-0.dll	6.2.9200.16492
iertutil.dll	C:\Windows\System32\iertutil.dll	11.0.9600.17631
MSOXEV.DLL	C:\Program Files\Common Files\Microsoft Shared\OFFICE15\MSOXEV.DLL	15.0.4569.1503
powrprof.dll	C:\Windows\System32\powrprof.dll	6.1.7600.16385
