[Qgis-user] OTB on win: please check
McDonaldR
McDonaldR at angus.gov.uk
Tue May 19 02:14:40 PDT 2015
Hi Paolo
Running QGIS Wien 2.8.2 on Win 7 32
Testing OTB Vector Data Manipulation - Concatenate
Dialogue opens, can select layers (2 x postgis tables) to concatenate, click RUN and process starts and then freezes. OTBxxxxxx.exe runs in task manager consuming a significant amount of memory then fails with error:
Oooops! The following output layers could not be open
Concatenated VectorData: C:\Users\MCDONA~1\AppData\Local\Temp\processing\f20a3117d3b14d3f806ca03ba62026e6\out.shp
The above files could not be opened, which probably indicates that they were not correctly produced by the executed algorithm
Checking the log information might help you see why those layers were not created as expected
Running again with 2 shapefiles and process completes successfully.
Does that help?
Ross
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
Sent: 19 May 2015 10:06
To: qgis-user
Subject: [Qgis-user] OTB on win: please check
Hi all,
could some Windows user please check whether OTB is installed and working under Processing, both on 32 and 64 bit standalone installations? You do not need to do anything special, just run an alg whatsoever (e.g. segmentation meanshift on a small ortophoto).
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
