[Qgis-user] Editing processes broken from 2.6.1 to 2.8.2
Bernhard Ströbl bernhard.stroebl at jena.de
Tue May 19 05:49:03 PDT 2015
Hi Ross,
I am addressing the second error as it comes from the DigitizingTools
plugin.
Questions to make this reproducible for me:
1) Are you using the most current version of the plugin?
2) Is there any differences between the CRS of the layer(s) and/or the
project?
3) Which QGIS version are you using on which platform?
Bernhard
Am 19.05.2015 um 12:42 schrieb McDonaldR:
> Hello List
> I have a process that works perfectly in Brighton 2.6.1 but is broken in
> Wien 2.8.2.
> I have two Postgis polygon layers loaded in QGIS – MR and RC.
> I copy some polygons from Ordnance Survey MasterMap Topography layer and
> paste into a memory layer.  In the memory layer the polygons are merged
> and edited until correct.  Then this new polygon is copied into MR
> (there are three mandatory fields which have to be filled at this
> point).  When I save my MR edits a series of triggers in the database
> update various fields (area, x, y, centroids, etc).  Then I copy the new
> feature(s) in MR and paste into RC.  Polygons are merged if required.
> Again, a series of triggers on the RC table update some fields.
> There are three processes that throw errors in 2.8.2
> 1.Selecting a polygon in MR and using the node tool to edit and move
> nodes fails with a “could not snap to feature in current layer” error.
> QGIS will crash with data written to a minidump file after selecting
> node tool, selecting a node and dragging it. Crash on release.
> 2.Selecting overlapping polygons in MR and RC and using the “cut with
> polygon from another layer” tool to cut RC with MR. That returns the
> error below:
> An error has occured while executing Python code:
> Traceback (most recent call last):
>    File
> "C:\Users\me\.qgis2\python\plugins\DigitizingTools\tools\dtcutter.py",
> line 94, in process
>      bbox = cutterGeom.boundingBox()
> AttributeError: 'NoneType' object has no attribute 'boundingBox'
> Python version:
> 2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
> QGIS version:
> 2.8.2-Wien Wien, 1b929ef
> 3.Pasting from MR into RC does not carry over attributes (the field
> names are the same) and the triggers don’t run on the RC table.
> While this is very probably user specific we’d appreciate any suggestions.
> Thanks in advance
> Ross
> *Ross McDonald *|**GIS Data Coordinator | Resources Department, IT
> Division | Angus Council, Angus House, Orchardbank Business Park,
> Forfar, DD8 1AT
> T: *01307 476419* | F: 01307 476401 | E: mcdonaldr at angus.gov.uk
> <mailto:mcdonaldr at angus.gov.uk> **
> This message is strictly confidential. If you have received this in
> error, please inform the sender and remove it from your system. If
> received in error you may not copy, print, forward or use it or any
> attachment in any way. This message is not capable of creating a legal
> contract or a binding representation and does not represent the views of
> Angus Council. Emails may be monitored for security and network
> management reasons.Messages containing inappropriate content may be
> intercepted. Angus Council does not accept any liability for any harm
> that may be caused to the recipient system or data on it by this message
> or any attachment.
> __________ Information from ESET Mail Security, version of virus
> signature database 11649 (20150519) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user mailing list
> __________ Information from ESET Mail Security, version of virus signature database 11649 (20150519) __________
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 11650 (20150519) __________
http://www.eset.com
