[Qgis-user] Editing processes broken from 2.6.1 to 2.8.2
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Tue May 19 06:23:38 PDT 2015
Just out of curiosity: What is MR and RC ???
Am 19.05.2015, 12:42 Uhr, schrieb McDonaldR <McDonaldR at angus.gov.uk>:
> Hello List
> I have a process that works perfectly in Brighton 2.6.1 but is broken in
> Wien 2.8.2.
> I have two Postgis polygon layers loaded in QGIS – MR and RC.
> I copy some polygons from Ordnance Survey MasterMap Topography layer and
> paste into a >memory layer.  In the memory layer the polygons are merged
> and edited until correct.  Then >this new polygon is copied into MR
> (there are three mandatory fields which have to be >filled at this
> point).  When I save my MR edits a series of triggers in the database
> update >various fields (area, x, y, centroids, etc).  Then I copy the
> new feature(s) in MR and >paste into RC.  Polygons are merged if
> required.  Again, a series of triggers on the RC >table update some
> fields.
> There are three processes that throw errors in 2.8.2
> 1.      Selecting a polygon in MR and using the node tool to edit and
> move nodes fails with a >“could not snap to feature in current layer”
> error.  QGIS will crash with data written >to a minidump file after
> selecting node tool, selecting a node and dragging it. Crash >on release.
> 2.      Selecting overlapping polygons in MR and RC and using the “cut
> with polygon from >another layer” tool to cut RC with MR. That returns
> the error below:
> An error has occured while executing Python code:
> Traceback (most recent call last):
>  File
> "C:\Users\me\.qgis2\python\plugins\DigitizingTools\tools\dtcutter.py",
> line 94, >in process
>    bbox = cutterGeom.boundingBox()
> AttributeError: 'NoneType' object has no attribute 'boundingBox'
>> Python version:
> 2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
> QGIS version:
> 2.8.2-Wien Wien, 1b929ef
> 3.      Pasting from MR into RC does not carry over attributes (the
> field names are the same) >and the triggers don’t run on the RC table.
> While this is very probably user specific we’d appreciate any
> suggestions.
> Thanks in advance
> Ross
> Ross McDonald | GIS Data Coordinator | Resources Department, IT Division
> | Angus Council, >Angus House, Orchardbank Business Park, Forfar, DD8 1AT
> T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk
> This message is strictly confidential. If you have received this in
> error, please inform the sender and remove it from your system. If
> received in error you may >not copy, print, forward or use it or any
> attachment in any way. This message is not capable of creating a legal
> contract or a binding representation and does >not represent the views
> of Angus Council. Emails may be monitored for security and network
> management reasons. Messages containing inappropriate >content may be
> intercepted. Angus Council does not accept any liability for any harm
> that may be caused to the recipient system or data on it by this
> >message or any attachment.
Erstellt mit Operas E-Mail-Modul: http://www.opera.com/mail/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150519/be505190/attachment.html>
