[Qgis-user] OTB on win: please check
Paolo Cavallini cavallini at faunalia.it
Tue May 19 08:22:19 PDT 2015
Il 19/05/2015 16:57, Redoute ha scritto:
> Am 19.05.2015 um 11:18 schrieb Paolo Cavallini:
>> Now we need a test for 64 bit installations (please
>> note: the 64 bit installer; you might have installed a 32 on 64, this
>> would not count).
> I tried Orfeo Toolbox, Concatenate, with two PostGIS line layers, save
> to temporary file.
> Uncaught error while executing algorithm
> Traceback (most recent call last):
>   File
> "C:/Users/User/.qgis2/python/plugins\processing\core\GeoAlgorithm.py",
> line 232, in execute
>     self.processAlgorithm(progress)
>   File
> "C:/Users/User/.qgis2/python/plugins\processing\algs\otb\OTBAlgorithm.py",
> line 183, in processAlgorithm
>     commands.append(path + os.sep + self.cliName)
> TypeError: unsupported operand type(s) for +: 'NoneType' and 'str'
> Same with two shapefiles.
> QGIS 2.8.2-Wien 64 Bit on Windows 8.1
Interesting. Here, applying it to the same layer loaded twice (to avoid
inconsistencies), I get:
Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion
`map->l_init_called' failed!
Probably a bug in OTB, anyway it seems installed and running.
Thanks for the check.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
