[Qgis-user] new issue with raster calculator
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue May 19 09:07:09 PDT 2015
Works for me.  Placing a "," rather that a "." decimal results in a
"expression invalid" so that can't be it.  Are you really getting Nan?
Use the "value plugin" to look at this or look at the histogram in layer
properties.  Sometime it is just the image scaling that is off.  Send a
sample file to test if it's still an issue.
Nicolas
Le 2015-05-18 09:04, Giacomo Fontanelli-2 [via OSGeo.org] a écrit :
> Dear community
> I have a raster layer with pixel values ranging from -8 to -11.
> when I do "layer1 at band1" * 0.1 I get a map with only 0 and Nan, instead
> when I do "layer1 at band1" / 10 I obtain the map with correct values.
> What do I do wrong?
> Thank you very much
> Qgis-user mailing list
> [hidden email] </user/SendEmail.jtp?type=node&node=5206199&i=0>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/new-issue-with-raster-calculator-tp5206199.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/new-issue-with-raster-calculator-tp5206199p5206475.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150519/7e8d5e2f/attachment.html>
