[Qgis-user] 32bit gdal gdal modules
Even Rouault even.rouault at spatialys.com
Wed May 20 08:01:50 PDT 2015
Le mercredi 20 mai 2015 16:54:53, Nicolas Cadieux a écrit :
> Hi,
> The problem with gdal_merge seems to be with the input parameters I used to
> deflate the file. Locks at 4GB file size. Cheers
You may need to explcitely add -co BIGTIFF=YES when generating compressed TIFF
that will be larger than 4GB. The GeoTIFF driver has a heuristics to determine
if a bigtiff file must be generated or not, but it's not bullet-proof. In recent
versions (GDAL 1.11 and above likely) you should get an error message "Maximum
TIFF file size exceeded. Use BIGTIFF=YES creation option."
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> www.archeotec.ca
> On May 19, 2015 12:01, "Even Rouault-2 [via OSGeo.org]	"
> <ml-node+s1560n5206474h55 at n6.nabble.com> wrote:
> 	Le mardi 19 mai 2015 17:58:33, [hidden email]  a écrit :
> > Hi,
> > It seems that both gdal_contour and gdal_merge in QGIS 2.6 and 2.8
> (both > 64bit windows installs on Windows 7_64) are still in 32 bit.
> Both stop > when output files hit 4 194 304KB (.tiff or .shp) Is there
> a way around > those limitations?
> 32 or 64-bit builds should have no influence on the limitation of output
> files. A 32-bit build can certainly handle files > 4 GB.
> .shp are limited to 2GB due to the format anyway.
> .tif might be limited to 4 GB with libtiff 3, but are no longer limited
> with libtiff 4 with BIGTIFF enabled.
> > Thanks
> > Nicolas
> > Qgis-user mailing list
> > [hidden email]
> > http://lists.osgeo.org/mailman/listinfo/qgis-user --
> Spatialys - Geospatial professional services
> http://www.spatialys.com _______________________________________________
> [hidden email]
> 		If you reply to this email, your message will be added to the
discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/32bit-gdal-gdal-modules-tp5206472p5206
> 474.html
> 		To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38@n6.nabble.com To unsubscribe from Quantum
> GIS - User, click here .
> 		NAML
> 669.html Sent from the Quantum GIS - User mailing list archive at
> Nabble.com.
