[Qgis-user] Why does clipping a raster alters cell size? (Luciano La Sala)
Luciano La Sala lucianolasala at yahoo.com.ar
Wed May 20 08:21:04 PDT 2015
Thank you very much Nicolas for your response. I have no idea how to use
use the -tr xres yres switch in gdalwarp.
However, I solved the problem using GDAL's algorithm "Clip raster by
mask layer" and by seting the option "Keep resolution of output raster"
to "Yes". That produced a .tif file with equal pixel size (200, -200).
Following, I convert this GeoTIFF to .ASC format using: "Raster >
Conversion > Translate (Convert format)" and the setting the Output file
to [GDAL] Arc/Info ASCII Grid (*.asc *.ASC).
The result is three files: the auxiliary file .aux, the coordinate
system file .prj, and one more filename of File type FILE that can be
opened with Notepad. Disappointingly, no .asc file was created. What am
I doing wrong? I need .asc files of my environmental variables to be
later processed using other software.
Thanks!
El 5/20/2015 a las 6:02 AM, qgis-user-request at lists.osgeo.org escribió:
> Send Qgis-user mailing list submissions to
> 	qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>     1. Re: Error installing QGIS 2.8.2-1 on Mac (Jacopo Tonetti)
>     2. Draw square or line and see meters (elmalle)
>     3. Re: Error installing QGIS 2.8.2-1 on Mac (Jes?s)
>     4. Re: Error installing QGIS 2.8.2-1 on Mac (William Kyngesburye)
>     5. Why does clipping a raster alters cell size? (Luciano La Sala)
>     6. Re: Why does clipping a raster alters cell size? (Nicolas Cadieux)
>     7. How I create web gis through Qgis (Debajyoti Ghosh)
>     8. Re: new issue with raster calculator (Bernd Vogelgesang)
>     9. Re: How I create web gis through Qgis (McDonaldR)
> Message: 1
> Date: Tue, 19 May 2015 22:23:33 +0200
> From: Jacopo Tonetti <jacopotonetti at gmail.com>
> To: Jes?s <jesusl.temez at gmail.com>
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Error installing QGIS 2.8.2-1 on Mac
> Message-ID:
> 	<CAJnh74mJHzhAJEnXJ6PmQ_UQf_n04p5OnMZONg8UJMwYREaN2Q at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi, seems that you have an older version of PROJ library. Did you download
> the package or install via homebrew? I recommend the latter (but you should
> use command line), I followed this
> <https://github.com/OSGeo/homebrew-osgeo4mac/wiki/Developing-on-QGIS-using-OSGeo4Mac>
> guide and everything is fine, same OS and version of QGIS.
> j
> 2015-05-19 19:38 GMT+02:00 Jes?s <jesusl.temez at gmail.com>:
>> Trying to install 2.8.2-1 on a Mac (10.9.5) I find this error:
>> Dyld Error Message:
>>    Library not loaded: /Library/Frameworks/PROJ.framework/Versions/4/PROJ
>>    Referenced from: /Applications/QGIS.app/Contents/MacOS/QGIS
>>    Reason: Incompatible library version: QGIS requires version 10.0.0 or
>> later, but PROJ provides version 8.0.0
>> Binary Images:
>>      0x7fff6810f000 -     0x7fff68142817  dyld (239.4)
>> <7AD43B9B-5CEA-3C7E-9836-A06909F9CA56> /usr/lib/dyld
>>      0x7fff8bc7f000 -     0x7fff8bc7ffff  com.apple.ApplicationServices (48
>> 48) <3E3F01A8-314D-378F-835E-9CC4F8820031>
>> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Applicat
>> ionServices
>>      0x7fff8bc9f000 -     0x7fff8bd0bfff  com.apple.framework.IOKit (2.0.1 -
>> 907.100.14) <10932113-9F7E-38A0-A158-A019A555CAC3>
>> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
>>      0x7fff8dd59000 -     0x7fff8df3efff  com.apple.CoreFoundation (6.9 -
>> 855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB>
>> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundatio
>> n
>> I delete old version first but I can't open new version when finishing the
>> installation. I got this message: Qgis can't be open due to a problem.
>> Any idea? Thanks
>> Jesus
Luciano F. La Sala
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
Cátedra de Epidemiología
Departamento de Biología, Bioquímica y Farmacia
Universidad Nacional del Sur
San Juan 670
Bahía Blanca (8000)
Argentina
