[Qgis-user] Need confirmation - Identify Results not showing Area
RNanclares raulnanclares at gmail.com
Wed May 20 12:07:02 PDT 2015
Hi there,
i have been working with the 2.8.2 for a few days and found really weird
bug.
If i load a project (2.8.1 project saved as 2.8.2) and then use the identity
tool on some polygons the area showing in the Identity Results panel is
0.000 m2. If i load the same polygon layer by itself the Identify Results
panels shows the area correctly.
Now if i create a new project from scratch with the same layers i get the
correct area in the Identify Results Panel.
All layers are in UTM WGS84.
Any idea what could be causing this behavior?
Cheers
View this message in context: http://osgeo-org.1560.x6.nabble.com/Need-confirmation-Identify-Results-not-showing-Area-tp5206725.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
