[Qgis-user] Import to SpatiaLite from file geodatabase
Alex Mandel tech_dev at wildintellect.com
Sun May 24 09:56:47 PDT 2015
Of course that won't work in this case as DBF does not support Date-time
in a single field.
Back to the original question, if I'm understanding you are importing 2+
tables and joins between those tables aren't working when you try to
join by Date-Time?
If you really want things to work in SQLite use unixepoch to match the
join. Are you using the QGIS join tool for this? I would write a view in
sqlite/spatialite that joins the tables. It sounds like your issue stems
from how QGIS read the spatialite tables and tries the join. If you do
it with SQL then you can more finely control how the matches work (like
the above mentioned epoch conversion can be done on the fly).
PS: ogr2ogr should be able to batch convert your db consistently.
Thanks,
Alex
On 05/24/2015 09:09 AM, Bernd Vogelgesang wrote:
> Haven't worked with spatialite for a while, but by that time I needed to
> work with DB Manager, QSpatialite and the Spatialite GUI to get things
> done. Variety is nice, but having to use 3 tools is a bit too much imho.
> Actually I would have like to move all my work to spatialite, but as
> qgis still seems to be very shape-o-centric (and postis is no option)
> and it's hard to remember what syntax to use in this tool and which
> function was in that, but not in the other, or the other way round, led
> me on the path of lowest resistance: using shape files :(
> No offence, just a pitiful remark ;)
> Cheers
> Bernd
> Am 24.05.2015, 17:13 Uhr, schrieb Paolo Cavallini <cavallini at faunalia.it>:
>> Il 24/05/2015 17:03, James Wood ha scritto:
>>> I was afraid
>> No problem with that, James - I just want to understand the real needs
>> of users. My underlying idea is that variety is good, but too much
>> duplication scares users away, so we're trying to reduce it when
>> appropriate and feasible (remember the good old days where everything in
>> QGIS was double? labelling, styling, etc.).
>> All the best, and thanks for the feedback.
