[Qgis-user] failed - OpenStreetMap import
Andre Joost
andre+joost at nurfuerspam.de
Tue May 26 21:36:26 PDT 2015
Am 27.05.2015 um 05:32 schrieb K Imran M:
> Hi Jim,
> I am not using any extra plugins but the existing ones coming with QGIS.
> I clicked
> Vector->OpenStreetMap->Download Data <No problem here>
> But, then
> Vector->Import Topology from XML
> then I clicked OK
> Immediately, I received this error:
> failed to import OSM data:
> XML error: Premature end of document
The imported file from step one is a text file. Can you open it with a
text editor? It should end with </osm>.
If it looks complete, you can drag and drop it from the Windows Explorer
directly into the table of content of QGIS. Does that work?
HTH,
André Joost
