[Qgis-user] matching .prj (ArcGIS) with CRS in QGIS
Andrew amcaninch at gmail.com
Sat May 30 15:41:24 PDT 2015
The difference between the 2 projections you mentioned is that the first,
"Kertau (RSO)/RSO Malaya (m) (EPSG:3168)" uses meters as the units and the
second, "Kertau (RSO)/RSO Malaya (ch) (EPSG:3167)" uses chains.  you can
tell from the "(m)" and "(ch)" at the end.The .prj specifies the Units as
meters, So I think if you specify the projection as EPSG:3168 that should
work.
On Sat, May 30, 2015 at 8:22 AM, K Imran M <drki.musa at gmail.com> wrote:
> Hi all,
> I am new to GIS so I apologize for this rather basic question.
> I have a shapefile (ArcGIS) with the corresponding .prj file coded as
> below:
> PROJCS["Kertau_RSO_Malaya_Meters",GEOGCS["GCS_Kertau",DATUM["D_Kertau",SPHEROID["Everest_1830_Modified",6377304.063,300.8017]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Rectified_Skew_Orthomorphic_Natural_Origin"],PARAMETER["False_Easting",804671.299775],PARAMETER["False_Northing",0.0],PARAMETER["Scale_Factor",0.99984],PARAMETER["Azimuth",-36.97420943711801],PARAMETER["Longitude_Of_Center",102.25],PARAMETER["Latitude_Of_Center",4.0],PARAMETER["XY_Plane_Rotation",-36.86989764584402],UNIT["Meter",1.0]]
> My questions are:
> 1) when I call this shp file into QGIS, which CRS should I choose to match
> the prj file?
> 2) does it match the Kertau (RSO)/RSO Malaya (m) (EPSG:3168) which has
> these codes
> +proj=omerc +lat_0=4 +lonc=102.25 +alpha=323.0257905 +k=0.99984
> +x_0=804670.24 +y_0=0 +no_uoff +gamma=323.1301023611111 +a=6377295.664
> +b=6356094.667915204 +units=m +no_defs
> 3) or does it match the Kertau (RSO)/RSO Malaya (ch) (EPSG:3167) which has
> these codes
> +proj=omerc +lat_0=4 +lonc=102.25 +alpha=323.0257905 +k=0.99984 +x_0=40000
> +b=6356094.667915204 +to_meter=20.116756 +no_defs
> Any help is greatly appreciated
> Thanks
> Kamarul
> Dr. Kamarul Imran Musa,
> M.D. M.Community.Med.
> Associate Professor (Epidemiology and Biostatistics) &
> Public Health Physician
> Dept of Community Medicine
> School of Medical Sciences
> 16150 Universiti Sains Malaysia, Kbg Kerian
> Kelantan
> Thomson Reuters researchID: http://www.researcherid.com/rid/G-4864-2010
> Google-scholar:
> http://scholar.google.co.uk/citations?user=aZyayMgAAAAJ&hl=en&authuser=1
> blog: http://designdataanalysis.wordpress.com
> email : drkamarul at usm.my <drkamarul at kb.usm.my> , k.musa at lancaster.ac.uk
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150530/2cbd93f2/attachment.html>
